Re: PICTURES-Different wheels for Alfa`s.
Ronal A1 suite the GTV6 best in my opinion:
Or the 164 QV/Q4
Or the 164 QV/Q4
Nice car with cool compomotives
- image.jpg (190.58 KiB) Viewed 10969 times
Love these wheels .
- image.jpg (175.22 KiB) Viewed 10800 times
schnitzer bmw?
-charles-
Compomotive made for Alfa GTV 3.0 in SA . These gave better cooling than the mesh type compos in racing . That's what it found anyway . This GTV 3.0 has much wider dishes than the factory 7.5 j
don't you have problems with rubbing the tires against the firewall/bulkhead, especially when steering?
when i had my speedline mistrals fitted it rubbed quite bad
-charles-
Those speedlines look good . Need some more light in pic on the wheels if you get another chance to take a pic to show them off . On the 15" they just touch inside arch on dust cover but on 16" you have to do some surgery by heating and knocking back the seam by 15mm . Got be carefull not to set the car alight inside though .
the speedlines are 17"
here's a pic of a single rim before the tires went on
-charles-
here are the rims on mine, i think they're called Heroes racing or some such, can check for detailed specs if anybody is interested. theyre 15" by 195x215, i think.
- 1.jpg (232.22 KiB) Viewed 10546 times
'83 GTV6 stock with Wildcat exhaust system
What is the widest wheels that can be fitted to the rear of an Alfetta GTV6.
I have 265 X 15' Simmons rims V5 that I want to fit on mine.
I might have to roll the rear guards.
The Blue GTV6 in the main above picture , Does anyone know the rear wheel size thats fitted to it.
Alfaaa1 I think with very careful offset you could make them work. 265 will fit but will be tight. I've got 17x9 going on all four corners but it takes a few sneaky mods to get them in the front. 245/40's all round.
Hi 105gta,
I will fit them soon and post some photos.
Alfaa1 both front and rear will be dependent on wheel alignment specs and obviously ride height will play a roll.
Wheel offset around plus 40 in the front. And with 265's I'd guess around plus 25-30 on the back.
I have +22 with 9" wheels but also 2 deg neg camber on the rear. Without neg camber you my want to bring them in a little maybe +30
- image.jpeg (99.62 KiB) Viewed 9555 times
- image.jpeg (121.71 KiB) Viewed 9555 times
They look like Rota Titan.
Hi 75evo, yeah they are Titans.
