Andy Kress at Performatek has a full range of poly bushings for our cars.
http://www.performatek.com/
I don't know about anybody else, but I thought that installing the SZ spherical bearing was a REAL PAIN. Am I the only person who thought that the aluminum housing was TOO SMALL for the Uniball?
Also, SHOP AROUND if you decide to buy the pieces. There is a HUGE price differential, depending where you look. If you have the Alfa part numbers, try getting it from one of the places that orders it from Alfa directly. Even with the exchange rate, it can be a little cheaper. Also, the Uniball bearing can be bought cheaper from a bearing supply house in many cases. I did not see a quantum leap in handling performance with it, but it is nice to know that there isn't rubber in there.
Has anyone tried the spherical bearing for the Watts link pivot???
I saw it on the web someplace, was thinking about cobbling one up myself.
Anyone who wants to jump in here, please do, but I found that the most significant effect of stiffening up the suspension bushings was an improvement in the CONSISTENCY of my laptimes. Lax bushings seem to me to cause a lot of dynamic handling changes that you spend more time fighting than is necessary. When I stiffened up the car it really decreased my workload-because I was spending less time fighting the car.
-Al
Poly bushings & SZ DeDion
Al Mitchell
Reale Motorsports
#82 E Production
Alfa Romeo GTV6
Reale Motorsports
#82 E Production
Alfa Romeo GTV6
- Maurizio
A bearing in the watt pivot makes more sence. If you look at the lever effect of the dion from the side of the car. The watt gets about 5 times bigger forces then the front center pivot of the dion.
My setup is uniball in the watt linkage. And a poly bushing in the center of the watt linkage and the pivot point of the dion tube. Which works great for me.
Re: Poly bushings & SZ DeDion
I have bearings in my Watts link on the race car and it's tight. Very predictable and without suprises, one of those upgrades you will forget about after a while because it just feel natural...Reale wrote: Has anyone tried the spherical bearing for the Watts link pivot???
AMEN!Reale wrote: Anyone who wants to jump in here, please do, but I found that the most significant effect of stiffening up the suspension bushings was an improvement in the CONSISTENCY of my laptimes. Lax bushings seem to me to cause a lot of dynamic handling changes that you spend more time fighting than is necessary. When I stiffened up the car it really decreased my workload-because I was spending less time fighting the car.
No need to "set the car up" going into a turn, loading up the bushings before you really turn in.
You don't have to sit and anticipate what the car will do next...
Do you mean that one ?
http://www.international-auto.com/index ... sid=909110
BTW -I'v been dealing with Andy few times now and must say he's the gratest!!!
