Typhoon90
Rear shock bump rubbers
Post by Typhoon90 »
I just replaced the rear shocks with ones that don't have a bump rubber built in, is the extra 4" of travel on a fairly stock ride height 90 going to cause things to explode?
I couldn't see what would hit first with that extra 4" of suspension travel.....
Regards, Andrew.
Re: Rear shock bump rubbers
The bump stops should be inside the springs at the top.
GTV27
Post by GTV27 »
your shocks will bottom out and not like it
Jason
1983 GTV6 2.8 litre
Typhoon90
Post by Typhoon90 »
MD wrote:The bump stops should be inside the springs at the top.
Hey, you were right! They're kind of hard to see if you're not looking for them. I wonder why the shocks have bumpers too, probably someone fitted the wrong type...
Regards, Andrew.
