Xenon hedlight conversion
After trying various headlight modifications, including 100w globes with relays(spraying dangerously bright light), recroming the inners etc I have been inspierd by a mate of mine Peter, with his Xenon set up. I have just completed mine and with only 35w globes the visibility is remarkably different. The basis of these lights comes from the BM's.
- Img_1544.jpg (83.54 KiB) Viewed 11222 times
I guess this thread should have been under electrical , all apologies.
This however does influence the exterior looks of the car.
The nice part about this particular conversion is that the convex lenses are still kept. Here is another Xenon conversion using the entire BM light with the flat lens. This is probably the easiest way to do it.
- Img_1546.jpg (112.19 KiB) Viewed 11221 times
The above GTV belongs to DR. Les which started life as standard South African GTV3.0l then was then bored out to 3.5 and a multivalve heads fitted by Dawie in 1995. This motor was replaced with a new 3.0 24v motor about two years ago. Enough of history.
Here are a few pics of making the light (the hard way will post pics of the easy way)
- Img_1510.jpg (120.35 KiB) Viewed 11216 times
kev - that kicks ass.
I have 4 original new headlights for my RHD unit - still in their OEM boxes. I may keep them stored and play with this conversion type instead. What car model/type were these headlights out of ? And do you have the pics of doing it the easy way yet ?
PanchoRama
- Alfa GTV6 NZ
The h1 zenon kit is readily avaliable to put straight in with the existing lights(plus relay and fuse) which will definately be an improvement if your existing lights still have good lenses. What I liked about the BMW conversion was the 'projector lense" which gives you a far more 'intense' light.
I will put up pics on the weekend of the easy way of doing it and which BMW light was used.
Barry should be able to recognise the light on Les's GTV 3.0. Thats the easiest option however you dont have the convex lense.
All you do is epoxy the GTV headlight clips onto the BM light in the correct position and cut a small piece out the grill and the light slides in . Sounds easy but its still take a bit of time.
Good one Kev,My giulietta xenon is coming on well as you know..
The BMW units I used In the late 80`s were from the e30 325i.Looks the same as your pic above.I ground all the BMW mounnting lugs off the housing and then cut the Alfa lamps outer ring with its mounting lugs to fit the outside of the BM unit..
Simply epoxied it on IN THE CORRECT POSITION!! As you say,trim the grill slightly to fit..
Worked extremely well..
The easy way, finally. Take this BMW light and cut its mounting clips off. take an old GTV lamp and remove the mounting clips. Some clips can be removed with a par of pliers if the spot weld is not to strong or drill out the tiny spot welds. The mark the correct position on the BM lamp and epoxy the Alfa clips on. You dont even need to go Xenon route as these lights are pretty dam good.
Heres some pics of the Bm lamp before the clips were cut off.
- Img_1638.jpg (92.51 KiB) Viewed 10688 times
- Alfa GTV6 NZ
