Hi all, as the name suggests i live in botswana, (no alfa dealer) i have the only gtv6 2.5 here
there was something i noticed, the old bmw 318i matchbox, approximately the same age as the alfa series (1983-1986) have very similar looking front ends, as seen uin the link below:
http://germancarsforsaleblog.com/wp-con ... /57-12.jpg
is it possible that it can be molded to fit? could look sweet
BMW 318i front bumper/skirt compatibility?
'83 GTV6 stock with Wildcat exhaust system
Re: BMW 318i front bumper/skirt compatibility?
Everything can be modified to fit, it doesn't mean it's a good idea to do so...
Personally I would never try it, is your Alfa front destroyed?
its been ripped in half, the mounting points are ruined and the skirt is shattered :/ the bumper is only bent by about 20 degrees i just thought they looked similar enough to be cross compatible and may even look good, i ask because there are thousands of the "gusheshe" bmw here. so i wouldnt stuggle to find parts. also i believe the bmw and that alfa share some parts like fuel pump and fuel system too, theyre both bosche?
If possible to repair enough to arrive at the original shape and dimensions, why not make a fiberglass one as a replacement. If it is a good outcome, you may even be able to make some extra ones and recover your costs or save for next time?
If you want I can put you in touch with guys who have the moulds for my bumper/spoiler combo unit in SA . Maybe they can make a unit for you . It looks like the pics below
- image.jpg (113.2 KiB) Viewed 10733 times
- image.jpg (163.72 KiB) Viewed 10734 times
- image.jpg (237.43 KiB) Viewed 10734 times
those look really good! how much did you pay for them? ive been looking around and the cost of the bumpers aint cheap!
Hello,
I am Angelos from greece and I am interested in this bumper.
Can you give me contact details with the manufacturers?
Thank you in advance!
