Let's start from the beginning. When you're running your MS and want to control the ignition, then you get an EDIS-6 module and...don't know much.
One thing. On an L-jetronic->MS conversion you need a 36-1 trigger and sensor, right? But do you still need that stuff on a Motronic (164)->MS conversion? The Motronic's equipped engines already have two crank position sensors for ignition.
My goal is to make this understandable to every newbie like me
