Author Message
<  MegaSquirt Fuel Injection  ~  Problem with air temp-sensor.
PostPosted: Thu Sep 18, 2008 11:03 am
SilverSilverJoined: Fri Mar 17, 2006 5:17 amPosts: 29Location: Sweden
Hi!
I have my ms installed and is about to start tuning it. The problem I've encountered is that the MAT-gauge in megatune shows nada when engine is running. It lights up when I turn the key to mar-position but goes out when I crank and stays off when engine runs. Tried a different sensor just to rule that out.
I'm running with stock AFM, l-jet harness and an adapter to connect to ms.
Any ideas?
/Marcus
Offline Profile
PostPosted: Sun Sep 21, 2008 3:24 am
Problem solved! I had forgot to ground ljet-pin 6.
Offline Profile
Display posts from previous:  Sort by:
Page 1 of 1
Users browsing this forum: Yahoo [Bot] and 1 guest
Search for:
Post new topic  Reply to topic
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
