source for crank trigger wheel?
m4ff3w
Post by m4ff3w » Thu Nov 05, 2009 2:01 pm
Is there a source for a pre-made (sadly I do not have a machine shop) 2.5l crank trigger wheels?
Murray
Re: source for crank trigger wheel?
Post by Murray » Fri Nov 06, 2009 2:35 am
m4ff3w you can try contacting Greg Gordon through his website http://www.hiperformancestore.com/ he may be able to come up with something.
Brian16
Post by Brian16 » Thu Dec 24, 2009 12:50 pm
Hi,
Try http://trigger-wheels.com/store/ in the UK. They have a 36-1 wheel with an internal diameter of 114mm, which will fit the 115mm GTV6 crank pulley diameter with a small amount of machining.
// Brian.
La vita e troppo breve da non guidare un'Alfa
