installing the MS1, Wideband O2 sensor question
jazig.k
Post by jazig.k » Thu Sep 30, 2010 2:51 am
Iv finished building the ecu, and im just waiting to find another stock one to butcher for the plug to make a harness. im so egar to get it in im almost willing to butcher my only good one... :wink:
i bought a innovate wideband kit and gauge when i got my MS kit.
when i go to put it in the car, do i have to use the original NB o2 sensor for the megasquirt or can i just simply swap in the wideband and change the relevant settings on megatune?
im a little confused about the wiring really, the NB having only 2 wires and the WB having 5, or are the 3 extra just the heater, and gauge signal? honestly i havent looked back into the manual of the LC-1 since i thought of this, i presumed i would have to run the NB and WB...
what has everyone else done?
ill have another read of the manuals tonight and see what i can work out for myself.
thanks guys
Re: installing the MS1, Wideband O2 sensor question
Post by Mats » Thu Sep 30, 2010 4:52 am
Usually Innovate have a simulated NB output from their unit if you can't configure the MS to take a WB input (naturally, the WB would be better). There is usually a WB output from the Innovate stuff as well.
You must use the complete Innovate kit to get a WB signal (ot probably any signal) and you can not replace any connectors on the harness for the WBO2 sensor. This is VERY important to understand.
jazig.k
Post by jazig.k » Thu Sep 30, 2010 6:18 pm
thanks,
i understand i have to use the whole kit, and not just bit and pieces.
i had another read last night and brief google before bed, and the lc-1 has a WB signal [brown wire] and a NB [yellow].
from diyautotune's website FAQ i gather i can change the output of these signal wires, not sure if i can change the yellow to give a WB signal though. ill read more about that later.
the brown wire goes to the gauge to give the gauge its signal. can i just 'T' in to supply the megsquirt with a WB signal? or should i use the NB sigal by itself?
i can imagin t'ing in would cause a problem.
jazig.k
Post by jazig.k » Thu Sep 30, 2010 6:49 pm
http://www.msefi.com/viewtopic.php?f=38&t=36125
i found my answer!
thanks,
and im sure ill be back!
