Megasquirt Maps upload/download location
Michael
Post by Michael » Thu Aug 25, 2005 11:51 pm
Please post your Megasquirt (and Megatune files etc) map/config files in this location.
What file extension types are needed for Megasquirt? Let me know and I'll allow uploading of those types. Right now, you can post msq files. Post other files as .txt files in the interim.... example Megasquirt.log.txt
Please list specifics on your car with each file upload, in the message body or file description.
Michael
1981 GTV6
Michael
Post by Michael » Mon Aug 29, 2005 11:36 pm
Here is a list of supported types - attachments you can upload to this location:
.msq for Megasquirt map files
.ini for Megasquirt MT configuration files
.dmp for Megasquirt MT dumps
.vex for Megasquirt VE exports
.xls for logs
All can only be uploaded as plain text files (which is the format they should be in anyway)
Michael
1981 GTV6
Steve R
Post by Steve R » Fri Jan 27, 2006 5:31 am
Hi here's my running files for anyone who might find it helpful as a starting or reference point when tuning.
These were mainly tuned on the road then fine tuned on a rolling road using input from a wide band O2 sensor, where the car gave 172 rwhp at 6250 and a nice torque curve. No flatspots and no hiccups anywhere from tickover to redline.
FYI I'm running on ECU firmware version 020s9 using Laptop Megatune version MT225.b326
1/ All settings .msq
2/ Fuel table Export .vex
3/ Spark table Export .vex
S
Dyno at 172 rwhp.msq
All setting .msq dump
(1.77 KiB) Downloaded 1038 times
fuel table dyno 172.vex
Fuel table .vex export
(1.63 KiB) Downloaded 1000 times
spark table dyno 172.vex
Spark table .vex export
(1.66 KiB) Downloaded 1200 times
Two snowmen in a garden, one says to the other, "Can you smell carrots?".
Post by Mats » Fri Jan 27, 2006 6:40 am
Steve. Might be a good idea to write down what kind of engine you have and mods. :wink:
Steve R
Post by Steve R » Sat Jan 28, 2006 8:50 am
Fair comment Mats:
3.0 12 valve from a 75. Stock internals, 9.5:1 CR, stock heads, valves etc, stock plenum & runners.
Mods= CB AR6.104.294s cams, no AFM, Gregs inlet pipe & cone filter, CSC manifolds, no centre box, Ansa back box. Megasquirt full fuel & spark control.
Also I just updated the files attached to the earlier post, apologies I uploaded the wrong one the other day. :oops:
S
Tamariini
Post by Tamariini » Fri Sep 28, 2007 7:40 am
Does anyone of you have 3.0 V6 12V spark tables for turbo use? I'm building 75 3.0 V6 Turbo with Garrett GT3076R and Megasquirt and would be interested in some tables to start from. I really don't know how much advance i can use and need a starting point.
Also interested in fuel and VE-tables for this kind of engine, CR is ~8.3, cams from 192hp 164 V6 and injectors 390cc/min.
Thank you in advance.
-Marco
- Alfa 75 3.0 V6 Turbo +300kw -
- Alfa 159 2.2 JTS Berlina -
- Alfa GT 1.9JTDm 16v -
- Alfa GTV6 3.0 V6 24v -
gtv-racer
Re: Megasquirt Maps upload/download location
Post by gtv-racer » Tue May 12, 2009 12:24 pm
Hello,
I was wondering if anyone could help me with a MSII for a standaard 3.0 v6 basic setup files.
I have already supercharged my alfa GTV 916 2.0Ts but i did only the hardware part. It is putting out 200HP and 260Nm of torque with an eaton m45 @ 0.4 bar.
This time i wanna do it al myself. First i wat to make de MsII work on a standard 3.0v6 and the i'm gonna supercharge it.
I looked around at this place , very nice projects here.
Regards,
Peter
Post by Giuliettaevo2 » Tue May 12, 2009 1:37 pm
Welkom! :P :wink:
75 CHL
Post by 75 CHL » Sun May 30, 2010 7:30 pm
Hi I new in this forum but any one have a based map for Megasquirt for Alfa 75 2.0 Twins Spark. Thanks
michel75
Post by michel75 » Sat Oct 30, 2010 2:00 pm
Hi, I'm new here too... see that I'm a bit late...
Have a base map for standard ts and blown with a M45.
If still needed, I can post it, I guess...
75 2.0ts Compressore Racecar
Michael
Post by Michael » Wed Jul 06, 2011 7:57 am
1995 Alfa Romeo 164LS 24 valve engine
Standard Megasquirt-II PCB 3.57
MS2/Extra 3.1.0
Stock 164LS coils being run in wasted spark mode via a Toyota 1JZ/2JZ 6-channel igniter (Toyota part number 89621-22030)
2011-06-22_18.30.05PR_AfterRun3.msq
(78.75 KiB) Downloaded 582 times
Michael
1981 GTV6
madk4speed
Post by madk4speed » Fri Oct 21, 2011 11:10 am
michel75 wrote:Hi, I'm new here too... see that I'm a bit late...
If you can go ahead and post your tune, mine needs a bit more work, but due to long working hours the project has been delayed....
michel75
Post by michel75 » Mon Dec 23, 2013 1:02 pm
Guess I missed this... still in need, or up and running?
Eman911
Post by Eman911 » Sat Sep 08, 2018 6:56 am
Finished my MS2 build last year, 2.5L stock bottom end, home ported heads and runners, RJR 590/82 cams, FJ15 injectors, MS controlled spark.
162HP, 140 TQ
CurrentTune.msq
(117.78 KiB) Downloaded 15 times
Eman911
Post by Eman911 » Wed Oct 03, 2018 3:20 pm
Spent a little time today tuning start up and idle settings. Found the car needed more timing at low rpm. Set the 900 rpm range to 10, 1k to 8, and 1.5k to 9. Nice smooth stable idle at 1000rpm. Good enough for a race car.
