GTV6 3.0 24V
Here's some pics of my 1985 GTV6 with it's new Glenwood Motors engine. Needs a bit more mapping of part throttle but really sweet when above 4000 rpm....
Next step is to get rid of the restrictive standard 2.5 exhaust.....
- DSCN0864.JPG (50.5 KiB) Viewed 13969 times
- DSCN0865.jpg (62.4 KiB) Viewed 13969 times
- DSCN0867.JPG (54.6 KiB) Viewed 13967 times
- IMGP0799.jpg (60.94 KiB) Viewed 13971 times
- SydneyJules
- Mezevenf
Glad you finally got it going Nice power output.
Yours made more power than mine
1985 GTV6 2.5L 12v V6 - Red
1999 166 3.0L 24v V6 - Red
NightSpec
NightSpec
SydneyJules, the wheels looks to be Zender Milano.
I think they are 7x17.
Previously I didn't like these wheels, but they look great on this GTV6.
Are the center of the wheels painted in the same color as the lower part of car? Polished lip?
The wheels really look good, somehow the don't look quite original....
Alfa Romeo - The thinking man's car!
2004 Alfa Romeo Sportwagon 1.9 JTD
1986 Alfa Romeo GTV6 2.5
Hi Guys,
The wheels are custom billet wheels from the SZ (ES 30) design. The fronts are 16 x 7.5 and the rears are 16 x 8.5. Currently running Toyo T1-R tyres, fronts 205/50/16 and rears, 225/45/16.
Daniel, the headers are from Dawie and are ceramic coated. Beyond that, it's just hooked up to the current 2.5 stock system with a rear ansa twin tip muffler. Too restrictive especially the middle muffler with the pressed tube going under the dedion triangle. Hopefully will upgrade to a 2.5 or 3 inch system soon. I can't remember what it's rpm limiter is set at but no advantage gain running past 7000 rpm... power curve starts to taper.
Bernard, I still haven't got it running smooth and initial to part throttle is very jerky at times. Hopefully will get that sorted out soon. How's yours? I have to get the vacuum line re -routed to near the throttle body as it's running MAP on the Gotech. Shits me badly when applying initial throttle as it hesitates a split second...
Jules, I am in Perth, Western Australia.
Dan, the centre of the wheels are silver - was going to paint it the same as the lower part but I think the silver gives it a slight contrast. Will post a pic of the wheel soon.
Cheers
Cheers
http://www.81x.com/alfasz18/wheels these are the custom made 18" sz design. bteoh you had the outer rims changed?
