http://www.alfagtv6.com/bb/viewtopic.php?p=14986Maurizio wrote:video, video, VIDEO, VIDEO, VIDEO
Some more pics have surfaced:
(c) Anders Ohlsson
(c) Anders Ohlsson
(c) Anders Ohlsson
(c) Anders Ohlsson
(c) Anders Ohlsson
(c) Anders Ohlsson
I also took a bunch during the track-walk the evening before the race. If someone wants to see this very ondulated track from beside the track I can post some in this thread.
(c) Anders Ohlsson
(c) Anders Ohlsson
(c) Anders Ohlsson
(c) Anders Ohlsson
(c) Anders Ohlsson
(c) Anders Ohlsson
Yeah, looking at the pics I was going to ask how much negative camber you run on the fronts - 3, or so?Lots of camber as well.
The arm on the upright is adjusted to suit the new geometry. Sure, the camber on the inner wheel is way out there but unless I make the car very roll stiff there isn't much I can do.
- Maurizio
Nice pics (and vid ), so uprights are welded/upside down bj?. Geometry of the lower arm looks good with a wonderfull low front. (Note to myself try to implement in 15" wheels on my ts, to remove an extra 4cm ground clearance).
Did you try stiffer springs on the front, or is this a good compromise?
Banned.. ? Daily donky.. ==> BMW 325d
E36M3 (3.0) Ringtool ==> definitely BANNED!
Barry, yes, loads. I only show the good ones...
Maurizio, upside-down bj, tubular control arms, corrected steering arm on the upright and so on. Can't really say everything that's been done becaus I didn't do it, the car was bought in this trim and I have been concentrating on the driving since I knew the car had produced much better times then when I drove it the first year.
The spring rate is pretty firm, AR-bars are on the soft side and I'm thinking about making some changes in that department but I'm afraid it will turn into a superstiff/edgy car that is difficult to drive on the edge. Need to do some more thinking in that department before doing anything. The tracks are not all super smooth either.
On the other hand I am working on some pretty interesting stuff right now, can't tell you much right now because I need to check the feasibility before tell you guys. If it works I think it will be the bees knees though.
Watch this space for info later on...
- Maurizio
Some pics of the front suspension please, sounds nice
After long thinking about the subject I'm convinced that it doesn't matter that much which one you use (ar bar/ springs) to stiffen up the front. Coil-over springs are lighter, cheaper and more effective (shorter force loop). The good part of a ar bar is that it can be disconnected for a wet setup. To make life interesting: finding the good combo for dry wet - setup swappingspring rate is pretty firm, AR-bars are on the soft side
What's that, son? I can't really hear you..?Maurizio wrote:Some pics of the front suspension please, sounds nice
As long as the track is reasonalby smooth you're right, but you need to be reasonably in tune between roll- and pitch stiffness.After long thinking about the subject I'm convinced that it doesn't matter that much which one you use (ar bar/ springs) to stiffen up the front. Coil-over springs are lighter, cheaper and more effective (shorter force loop). The good part of a ar bar is that it can be disconnected for a wet setup. To make life interesting: finding the good combo for dry wet - setup swapping
To have a setup where you can simply disconnect the AR-bars and still have a balanced wet setup seem a little optimistic.
I'd rather have an adjustable bar and use good old trial and horror for a good wet-setup on the bars.
