AR75 hillclimb
Grdi
Re: AR75 3.0 24v from Croatia
Post by Grdi » Mon Oct 27, 2014 6:35 am
now diet and new painting in/out :wink:
aiming around 1050kg...w/o driver and 20l fuel
still have to do modifications on exhaust...has to be more open...
lower gear full throttle
Grdi
Re: AR75 hillclimb
Post by Grdi » Fri Nov 07, 2014 3:01 am
diet ongoing :wink:
planing to buy this tank, 30l, not big not small, right measure for hillclimb but also track/rally...
http://www.ebay.de/itm/ATL-8-Gallon-20x ... 19f0bd73be
Grdi
Re: AR75 hillclimb
Post by Grdi » Tue Jul 21, 2015 10:57 pm
small update...beside new color I've achieved 1050kg (w/o fuel).
Had some issue with 1.6 gearbox therefore currently running 2.0TS gearbox, too long, will swap back to 1.6 when find time.
Still driving shity semi-slick Federal 595RSR, finally deceided to invest into Michelin S8A and will see...
Alfa roars at 9:36min
https://www.youtube.com/watch?v=g0V5aJhzU2o
Few pics from last weekend hilclimb race in Croatia.
Joemart
Re: AR75 hillclimb
Post by Joemart » Wed Jul 22, 2015 10:09 am
Hi
I like how u have routed the exhaust... can u post some pics of how u did it? - how did u route it underneath?.. etc
Thank
Grdi
Re: AR75 hillclimb
Post by Grdi » Wed Jul 22, 2015 11:35 pm
And you know the reason why done this way...with typical approach, exhaust below the car it's too low and having issues when placing the car at the trailer etc...
During April and one of the track days shit happened :wink: new, stronger part done 8) fillister for rubber part missing on this pic but we did it too
Joemart
Re: AR75 hillclimb
Post by Joemart » Thu Jul 23, 2015 10:03 am
Hi... Exactly - far too low
Thanks..
how much heat does it generate inside the car?... and did cutting the floor board create any weakness in the structure?
75evo
Re: AR75 hillclimb
Post by 75evo » Thu Jul 23, 2015 10:28 am
I like the new giubo flange, Maybe I can make an Alfa flywheel to BMW guibo adapter.
Pretty sure cutting the flat sections floor will weaken the structure a little, but with a full cage which now becomes the new backbone of the car, it's probably not an issue.
Grdi
Re: AR75 hillclimb
Post by Grdi » Thu Jul 23, 2015 10:29 am
Of course not...75 is a f****** tenk :D very strong and no issues you mentioned
Grdi
Re: AR75 hillclimb
Post by Grdi » Sun Jul 26, 2015 2:22 pm
since I was looking for additional set of 15x7 wheels, finally found something interesting by fair price...
Grdi
Re: AR75 hillclimb
Post by Grdi » Mon Aug 31, 2015 10:56 pm
Hillclimb championship, Ilirska Bistrica, Slovenia
http://www.youtube.com/watch?v=82r8xKBpwEQ
Grdi
Re: AR75 hillclimb
Post by Grdi » Mon Sep 21, 2015 3:09 am
Buzet, Croatia - FIA Euro Championship Hillclimb race
2nd run yesterday
http://www.youtube.com/watch?v=FlJKJUeo51c
Grdi
Re: AR75 hillclimb
Post by Grdi » Wed Nov 11, 2015 7:57 am
Grobnik Track Day 08.11.2015
Re: AR75 hillclimb
Post by MD » Wed Nov 11, 2015 1:36 pm
I think Giulietta EVO2 said the ring and pinion apparently is shite.
I use more HP and torque than your 3 litre 24V with a 4.56 differential on the track and there are no issues other than a big grin... :D
75evo
Re: AR75 hillclimb
Post by 75evo » Thu Nov 12, 2015 12:12 pm
Looks sweet bro! Post some vids.
Grdi
Re: AR75 hillclimb
Post by Grdi » Fri Nov 13, 2015 7:18 am
I didn't record latest track day...nothing special, running around the track in the circle, boring unless you are not in some proto like e.g. Radical, Norma, Osela :wink:
having only this posted previsouly from hillclimb...we have soon (22nd of November) Formula Driver session based on Italian hillclimb approach with chicanes...will try 1st time to drive this
Locked
