Page 2 of 2
Re: festy - a pair of alfettas down under
Posted: Sun Oct 14, 2012 7:09 pm
by festy
And finally the new head is ready to go on:
- head1.jpg (116.58 KiB) Viewed 7969 times
- head2.jpg (81.46 KiB) Viewed 7969 times
At the rate I work, there's a good chance the car might be up and running by mid 2014
Posted: Thu Oct 18, 2012 1:17 pm
by kevin
Festy, I think you gonna overtake Mats soon
Posted: Fri Oct 19, 2012 1:41 am
by festy
I got it all back together this afternoon, then mucked around for half an hour getting the fuel pumps to prime.
Once there was fuel circulating, I hit the starter and it fired up first go.
Pretty happy about that
Posted: Fri Oct 19, 2012 1:16 pm
Sweet!
Posted: Wed Sep 30, 2015 3:17 pm
Hey festy,
2014 has been and gone. Where is your update, fella?
Posted: Wed Sep 30, 2015 5:52 pm
by festy
Umm yeah, probably due for an update
Back around the time of my last post in this thread, I was toying with the idea of turbocharging so I taught myself just enough CAD to draw this up
- nord exhaust flange
- 1.jpg (17.43 KiB) Viewed 7638 times
Then printed it out and glued to a piece of chipboard to see how close I was - imagine my surprise when the holes lined up with the studs
- template
- 3.jpg (123.44 KiB) Viewed 7638 times
So I then had half a dozen of them laser cut. It's one of the few things I've farmed out on this build, but my little plasma cutter wouldn't have coped too well and it would have taken me forever to do on the mill
- flange test fit
- it_fits.jpg (87.28 KiB) Viewed 7638 times
Next step - bore the exhaust ports at the correct(ish) angle:
- boring work
- boring.jpg (110.15 KiB) Viewed 7638 times
Seeing as I have no intention of chasing crazy horsepower, a log manifold will do for now
There wasn't enough clearance for some of the nuts, so I had to make some new ones that are 11mm across the flats. Now I can add "custom brass nuts" to the list of modifications
- aww nuts
- log1.jpg (96.71 KiB) Viewed 7638 times
And that's all the pics I can add to a single post, so to be continued...
Posted: Wed Sep 30, 2015 6:16 pm
by festy
Next up - add a flange for a T3 turbo
- rhs.jpg (83.35 KiB) Viewed 7637 times
Finish welding it all up, machine the face flat, and a quick coat of high temp flat black
- done
- manifold1.jpg (108.94 KiB) Viewed 7637 times
Then onto the turbo. It's an old Garrett TB0356 off a late 80's Saab. It was free, and appears to be in pretty condition where it counts.
It has a bespoke outlet stud pattern (and the studs were wrecked anyway) so I grafted on a V band flange instead
- vee1.jpg (109.37 KiB) Viewed 7637 times
Started work on a 2.5" dump pipe
- dump1.jpg (96.76 KiB) Viewed 7637 times
And my very intricate exhaust
- exhaust.jpg (184.04 KiB) Viewed 7637 times
Posted: Wed Sep 30, 2015 6:20 pm
by festy
then skip over a whole heap of dramas and distractions to how it sits today
- 1510.jpg (136.35 KiB) Viewed 7637 times
Posted: Wed Sep 30, 2015 6:30 pm
Good to see that you have been busy. Solved your radiator problems yet?
Posted: Wed Sep 30, 2015 6:42 pm
by festy
Not really.
I spent a few hours cleaning out the radiator as best I could, the garbage that I got out of it makes me think it's had a "stop leak" treatment at some point
It's improved to the point where it no longer overheats while idling at least, but doubt it would keep it's cool much beyond that.
Posted: Wed Sep 30, 2015 7:46 pm
by Jim K
Hey Festy, nice work but why go about it the long way?
All you had to do is ask and I would send you a 1.8T log manifold! We have some around here and the early single-plane versions are of no use as everyone looks for the later two-plane type. Damn, you would have saved yourself lots of time -unless you like the exercise that is!
In the pic below you see the two factory versions, early on top, later (and
expensive) bottom. Early ones were prone to cracking which is not the case with later ones. All with T3 pattern.
