The small tube coming off the side of the oil separator?
What is it suppose to connect to?
Its continuous with the tube coming out the bottom of the engine connection.
What's this for
Brett
Re: What's this for
looks like a drain back to the bottom of the sump for excess oil.havent seen one in that style before howevr the 164 style ones have the same thing.if your engine doesnt have a nipple for it to attach back to around the sump area or near the distributer, just block it off.
patzo_3l
3l gtv6 turbo 85'
2006 147 gta selespeed
1990 75 twinspark
1998 spider
2.0l gtv 85'
33 1.7ie
3l gtv6 turbo 85'
1990 75 twinspark
1998 spider
2.0l gtv 85'
33 1.7ie
Re: What's this for
i also have one!a bit difficult to see
i think it as the oil fumes catcher, the oil drops will go back into the engine
- IMG_3060.jpg (173.85 KiB) Viewed 4806 times
Re: What's this for
Thanks guys.
What I'll do with is use it to feed a drop of oil or two onto the thrust bearing that replaces my distributor.
I was just curios as to what alfa used it for as it doesn't appear in any of the manuals I have.
Brett
Re: What's this for
Lennart, doyou actually use your cars? Outdoors? That engine bay looks quite tidy I must say...
Re: What's this for
i am marc!
this engine hasn't run yet, it is dusty.
it is barry's 3,7 24v
Re: What's this for
ye im pretty sure that wat it is for. unusual though that all the v6's i have seen in australia dont have that little return nipple like yours, except for the later 164s ofcourse. ye looks like someone dipped that engine bay in some wax. even all the hoses and belts look imac.
patzo_3l
3l gtv6 turbo 85'
1990 75 twinspark
1998 spider
2.0l gtv 85'
33 1.7ie
3l gtv6 turbo 85'
1990 75 twinspark
1998 spider
2.0l gtv 85'
33 1.7ie
