75evo
Re: Need s some advice on an Alfetta GTV 3.2 V6 24v conversion
Post by 75evo »
Looks great. How low is the oil pan?
KevinR
Post by KevinR »
Looking really good .
Alfaaa1
Post by Alfaaa1 »
Hi 75evo, it sits about 10mm lower than the original lower sump.
I would like to thank all the guys on this website that had help me on this conversion till now.
No doubt I will be needing some more advice in the future as I progress on the GTV6 completion.
:D :D :D
75evo
Post by 75evo »
What ECU are you using mate? Autronic, Adaptronic or Haltech?
KevinR
Post by KevinR »
Did you take any pics of your front thermostat adaptor ?
Alfaaa1
Post by Alfaaa1 »
Hi 75evo
I will be using a Gotech Pro X ECU.
Hi Kevin I did not take a photo of the modified Thermostat housing by its self, Below is a photo of the housing on the engine. :D
75evo
Post by 75evo »
Loving those ITBs, did you get them from AHM?
Alfaaa1
Post by Alfaaa1 »
Yes got them from AHM,
Very happy with the quality.
KevinR
Post by KevinR »
Very neat ! Is this originally a 2.0 shell ? What bonnet ( hood )are you going to use as the 2.5 one does not fit on those throttles . Most guys use the 3.0 bonnet .
The sound those throttles make when you behind the wheel is glorious . It makes all that hard work worth it all !
Alfaaa1
Post by Alfaaa1 »
Hi Kevin,
Yes it was a 2.0 shell,
Had to do some changes on it to fit the V6.
I have fitted v6 drive line and hubs with the 3.0 larger drive shafts .
3.0 bonnet would you have photos ,
Just removed some rust from the doors and bonnet fitment was next. I wanted to fit the 2.5 bonnet :| , I have not yet tried fitting it.
KevinR
Post by KevinR »
Also depends on type of filters you are going to use . I can give you full sketch of bonnet or you can order one from a chap in UK who has good moulds for the bonnet and larger spoiler . If you do i know another chap in Oz who was going to order one so maybe you combine order .. or just simply modify your bonnet like the green 24v Gtv of Ale drig who is on forum .. probably easier and also good looking as you can do away with the plastic piece
Alfaaa1
Post by Alfaaa1 »
Hi Kevin ,
I am going to fit filter socks over the throttle rams.
I don't know what I will do yet with the bonnet.
I will work it out once I try fitting it.
Mite do something different, refer picture. :D
Picture 456 (1).jpg (141.45 KiB) Viewed 15252 times
75evo
Post by 75evo »
Love the hood scoop, should go well with stickers like "Git 'er done!" or "BIG BLOCK" :mrgreen:
Now work Alfaa1
I believe you’re in melbourne? Where about a?
My conversion and project is finally getting some momentum, although I’d love to have a look at yours.
May also be able to help with an SA 3.0 bonnet as I’m also going to run aHm throttles and An SA bonnet on my car.
Jules
75evo
Post by 75evo »
Jules, come on already, update your thread. It's on here somewhere. :lol:
