Engine starts and dies
Posted: Sun Nov 28, 2004 9:18 pm
I know this has been covered but can't find any old posts. '86 GTV-6 starts for a second then dies. This is after an extended (4 month) down period in which I did a lot of work and played with many electrical connections and included removing the dash and replacing all fuel hoses and vacuum hoses. Verified that the fuel pump is working, quiet pump though, I couldn't hear the pump but could hear the flow of fuel thru the hoses. Checked various grounds but thought I would check here for some ideas. I've seen this discussed many times on the old forum and thought that I could quickly get numerous suspects. Any ideas? It seems that I'm starting on my cold start injector but the main injectors are not firing.
Jason
Boise, Idaho
86 GTV-6
74 Spider
Jason
Boise, Idaho
86 GTV-6
74 Spider
