MerrilGordon
Stripped Threads in Exhaust Manifold Mounting Holes
Post by MerrilGordon »
Well I finally did it. Too many removals, replacements, and ham-fisted torqueings on my part. I stripped out the left rear hole for the exhaust manifold bolt. I’m still using stock cast iron exhaust manifolds so using those long bolts into the head.
I’m wondering if a longer bolt might find enough threads ?
Probably not a good thing to try.
I could drill out to the next size and use a larger bolt.
Don’t like having one different than all the others though.
Can the hole be drilled deeper without hitting a water jacket or something ?
Probably not a good idea either.
So there’s the Helicoil insert. Probably the best choice, but is there a better alternative ? Seems I remember reading about another type of insert recommended for Porsches that was stronger than a Helicoil. Any of you guys know about that one ?
Any recommendations welcome.
Merril
82 GTV6 3.0
Merril,imo the helicoil is more than sufficient for the job.You could of course go for the solid insert thingy,but I reckon its overkill.
matt
Post by matt »
I'd be interested to see how the helicoil used, are they strong enough for the cam "cap" bolts. I noticed a hairline crack in my cam/tappet cover at the middle off the exhaust side cam and one of the bloody cam cap bolts has been stripped, well i can't get enough torque on it :twisted: I assume this led to slight movement, enough to crack the cam cover slightly :evil: before i pulled the motor......
anyway be interested to see how this is all done!
Murray
Post by Murray »
Matt I used Helicoils on 3 of the 5 cylinder head bolts on an old 400cc Yamaha motorcycle I own.That was 10 years ago and they are holding up just fine.That was before I learnt about the importance of using a torque wrench when working with aluminium :lol:
MerrilGordon
Thanks for the input everyone. I'll go with the Helicoil.
Torque wrenches. Yea, I've got a big one but what's really needed is a small one for many of the fasteners into aluminum we have in our Alfas. I need to get one and not have any more screw-ups like this.
Merril
82 GTV6 3.0
Helicoil...definately strong enough..much stronger than the alu...sometimes hard to find specific metric sizes...use thread assembly lube
