5yearplan
Engine Weight
Post by 5yearplan »
Does anyone know how much a 2.5L 12v GTV6 engine weighs(Either as a complete assy. as pulled out of the car, or just the engine)? Also, the transaxle assy?
sh0rtlife
Post by sh0rtlife »
id LOVE to have this info....considering im fixing to add both the transaxle and engine to a 1200lb car
slyalfa
Post by slyalfa »
this is some stuff I found a while ago.
the link also has some tranny numbers too very cool..
http://66.102.7.104/search?q=cache:wU5B ... n&ie=UTF-8
weight
engine pounds ref. comments
Lexus V8 32V 1UZFE 4L 390
Toyota V8 32V 2UZFE 4.7L 475 Iron block in Toyota trucks
Alfa Romeo SOHC V6 375 (2)
Alfa Romeo 415/85T 279 (31) F1 four, '87 season
Alfa 155 V6 TI 242 (75) BTCC Class 1 race engine
Alfa Romeo Type 33 V8 286 (137) 2000cc DOHC, Chiti design, 1967
Alfa Romeo 1600 261 (150) (with cams, generator, distributer, oil,
etc but no manifolds or carbs)
Buick/Rover 215 V8 318 (and Olds)
Cadillac Northstar V8 484 (71)
Cadillac Northstar V8 403 (79) (bare, no accessories)
Cadillac Northstar V8 464 (80) (dressed)
Cadillac Northstar V8 404 (155) (without accessories)
Chevy 427 ZL-1 550 (35) all-aluminum, "20# lighter than SB"
Ford 5.0 V8 411 (171) 89 Mustang 5.0 GT (dry) inc: manifold,
carb(?), headers and alternator. Not
inc: starter, smog pump, power steering
pump, AC compressor, flywheel
1987 black Milano Verde
1972 White spider 2000 Veloce
5yearplan
Post by 5yearplan »
That's a nifty link, thanxs. :D
sh0rtlife
Post by sh0rtlife »
killer link thanx a ton
altho im saddened by the almost 400lbs that is 2.5 alfa
5yearplan
Post by 5yearplan »
sh0rtlife Posted: Thu May 17, 2007 10:44 am
Do you already have the engine and tranny assy?
sh0rtlife
Post by sh0rtlife »
yeah ive got a complete 87 milano lol..with asumeably a platinum transaxle as well as a spare 2.5 that came with the gtv6 and then theres thefront end and 4cyl 77 alfetta stuff that ive got
the milano is to be the doaner for my "project" ....guess ill have to see where i can shave some weight..was a 1200lb project befor removeing the drive trane and suspension.....shooting for a finished weight under 2000 but would love to see under 1800
5yearplan
Post by 5yearplan »
Cool project , good luck with the weight reduction. :D How much Hp are you shooting for? The car should be a beast when it's done if you ca get it under a ton, and a 10:1 power to weight.
sh0rtlife
Post by sh0rtlife »
if i can bring the weight down ill probably just change out the air intake setup and drop in some S cams and be done with it....a friend of mine has a lead on a wrecked 3.0 164 in someones front yard......that would be my ideal setup but the 2.5 in a light package should be fun as all hell being a light body and super small...its smaller than a early mini
does anyone know a different way to get to this info......the above link isn't working anymore?
Scott
sh0rtlife
Post by sh0rtlife »
ahhh crap ..well if someone gets ahold of the info into a text file id like a copy of it...ill try periodicaly to get into the site ...if i do ill copy it to text file as well
slyalfa
Post by slyalfa »
sh0rtlife
Post by sh0rtlife »
wooohoo...thats going in a text file for perminant keeping
THANKS SLY,
Scott
