Lucio
GTV6 piston ring set
Post by Lucio »
Dear friends,
I desperately need a complete set of piston rings for rebuilding my 2.5 V6 (GTV6 1981). It seems these are out of stock in Italy and so they appear on the IAP online catalogue.
Could you point me to a fast and reliable source for these?
Lucio
don't know if they have them in stock...but try:
http://www.hastingsmfg.com/index.htm
look under 'catalogue'.... master ...alfa romeo
Also:
Centerline Alfa
Lucio
Post by Lucio »
x-rad wrote:don't know if they have them in stock...but try:
Also:
Centerline Alfa
Hastings don't seem to sell to individuals. CenterlineAlfa seem to have them in stock, though I'm not 100% sure they are "standard". Can anyone have a look and confirm? (item #PR625)
Lucio
Hastings sells to individuals.. price is 153.09$ US plus shipping
Centerline has standard 2.5 rings in stock for about 118$ plus shipping to Italy of about 30$
1-888-750-2532 ask for Joe
Pssst...dont tell anyone,but you can use VW Combi rings on the Alfa...You have to widen the second ring groove by 1/2 mm....
Lucio
Post by Lucio »
x-rad wrote:Hastings sells to individuals.. price is 153.09$ US plus shipping
I'll go for the Centerline ones then. Thanks for the precious feedback!
Lucio
Lucio,
Hastings are moly rings and require the correct hone (320 grit)..also, read the break in instructions. Don't take the rings out of the box until you are ready to install so you don't mess up the order...
car guy
Post by car guy »
Ever consider using TOTAL SEAL piston rings. Very ingenious piston rings that really increase compression and reduce blow by. Call Summit racing they have them.
car guy
Post by car guy »
