Enrique
Fuse Block Diagram Needed
Post by Enrique »
I have a combination Milano/GTV6 factory manual. The manual includes a fuse block diagram for the Milano, but not the GTV6.
Can anyone provide me with a diagram that shows (1) the correct amperage for each fuse and (2) the components that correspond to each fuse?
Failing that, does anyone have recommendations as to where I can buy a manual that includes such a diagram? I'm hesitant shell out big bucks because, as I said, I already have a factory manual.
Thank you.
:idea:
twinspark6
Post by twinspark6 »
what year is your gtv6? There might be a small diffrence beetwen the early and late cars. I'll look it up.
Enrique
1985
Post by Enrique »
My car is a 1985 model.
twinspark6
Hope this helps. I found one for an 86 gtv6. I could only get it to work in a pdf format. Send me your e-mail address and I will send it off. It's too big to upload. Weird.
Enrique
fuse diagram
Post by Enrique »
Thank you! I sent you my e-mail address via a GTV6.com personal message. Check you GTV6.com inbox.
twinspark6
e-mail sent.
