Alfa romeo v8 engine
MALDI
Re: Alfa romeo v8 engine
Post by MALDI » Sun Oct 03, 2010 6:48 am
Flat plane cranks for the Montreal V8 are available:
http://www.okp.de/xtc2/105-Montreal/10- ... 10719.html
'84 GTV6 3.0L
'81 X1/9
Post by Mats » Sun Oct 03, 2010 11:26 am
cams too?
MALDI
Post by MALDI » Sun Oct 03, 2010 1:54 pm
No cams available apparently, but I would guess they are easier to make than a crank.
'84 GTV6 3.0L
'81 X1/9
Post by Mats » Sun Oct 03, 2010 10:29 pm
Or maybe you can use the stock ones by rotating them 90* crank? Guess that would be a strange way to make a 90* crank though... 8)
Post by la_strega_nera » Mon Oct 04, 2010 3:28 pm
For a flat cranked montreal, surely you'd just used 4cyl cams?
1966 GTV
1982 Suzuki "Bathurst" Katana
Post by Mats » Mon Oct 04, 2010 10:51 pm
la_strega_nera wrote:For a flat cranked montreal, surely you'd just used 4cyl cams?
Is there an obvious reason for them to fit? Didn't know the Montreal had two timing chains?
Post by la_strega_nera » Tue Oct 05, 2010 2:45 pm
My understanding is that the cam sprockets are used to allow for the rod width change in alignment and that the cams themselves are not bank dependent - and they already use so much of the nord architecture that there's a pretty damn good chance the 4cyl cams would drop in.
1966 GTV
Post by Mats » Tue Oct 05, 2010 10:38 pm
ok, I see wahat you mean. But surely the firing order for the 90* crank is not working with the 4-cyl cams? The 180* I can understand but the 90*?
Post by la_strega_nera » Wed Oct 06, 2010 2:28 pm
I thought we were talking about a flat crank?
1966 GTV
Post by Mats » Wed Oct 06, 2010 10:11 pm
Mee too. But somewhere along the line the references fell away and in the last post it sounded like you meant that one could use the nord cams in a "normal" Montreal. I just wanted to clarify.
michel75
Post by michel75 » Mon Dec 23, 2013 12:54 pm
Is this engine running yet?
Or did you buy a Montreal unit?
75 2.0ts Compressore Racecar
Post by 75evo » Thu Dec 26, 2013 1:27 pm
You can look at a FB page
https://www.facebook.com/oliver.koerfgen.5
There is a video of a Monty with a Tipo 33 crank.
