xrad
Cam question 164 v Verde
Post by xrad »
Any difference in 164S and Verde 3.0 cams? IAP lists the same part number.
Re: Cam question 164 v Verde
Post by la_strega_nera »
The 164S cams have a slot on the back of the Front (left hand) cam to drive the distributor.
1966 GTV
1982 Suzuki "Bathurst" Katana
xrad
Post by xrad »
yep, thank you. I was wondering more about the ramp and duration..
A few degrees more on the intake and 1mm more lift, I think. Not a huge difference. You'd be better or getting something with more lift on both the exhaust and intake, and figure out what lobe centers to use. Also, it's not just the peak values, what about the ramp. Nobody tells you the ramp, especially not companies like Colombo etc. Contact alfar7@aol.com for a custom set of cams. Or ask JimK what Catcams is suitable for a street engine. (catcams.be).
xrad
Post by xrad »
Thanks Zamani. I do miss my C+B cams......
Alfar7 will be getiing my transaxle soon for some gear work. I will stick with stock 164S cams for now.
