Exhaust valves
Exhaust valves
Post by 75evo » Sat Nov 05, 2011 3:53 pm
I Just got plain steel valves for my 3.0 V7. The heads are going to be shaved so I will end up with 11:1 compression.
The valve stem looks so damn wide, can I trim it down a little below the guides to improve flow and lose some weight?
Thanks.
scott.venables
Re: Exhaust valves
Post by scott.venables » Tue Nov 08, 2011 2:33 pm
You could convert to 8mm or 5/16" stems and then getting guides to suit. 9mm Is a strange size that's for sure. There might be a little machine work involved if you can't find some with the groove in the right place though.
WhizzMan
Re: Exhaust valves
Post by WhizzMan » Sat Nov 12, 2011 12:14 am
Trimming down the guides depends on your cam profile, valve spring strength and max RPM you'll be going. Imagine the force on the valve if you'd be getting a little float on closing at 7800 rpm and the extra strong springs whacking it onto the seat. That's what would cause deformation and eventually, breaking of the stem.
From what I hear from Guy Croft, the flow of a well ported head will hardly be influenced with thicker/thinner valve stems, it's mainly weight loss that is the benefit of trimmed down valve stems. At 9mm there may be a bit more influence, but the money spent on machining down the stems would probably be more beneficially used on a radiused 3 angle seat job or something like that.
Re: Exhaust valves
Post by MR2 Zig » Sat Nov 12, 2011 7:10 pm
Adding to that is that the real restriction in the 12v is the size of the intake runners (according to Jim K.).
hope that helps,
