New 24v ITB's
yetyGTA
Re: New 24v ITB's
Post by yetyGTA » Thu Feb 13, 2014 1:05 pm
Decided to go slightly different route and build own budget ITB kit using available parts. First "half" arrived today from Latvia (just a matter of luck, where they have them cheapest). They are from a Triumph 675 which as you can see is a three cylinder.
Nevertheless you can split them one by one and that is my plan. Internal diameter seems to be perfect - 45 mm which is almost the same as the OEM chrome intakes. My next step will be to drill the back to get a circle shape and weld the holes for injectors as they will go where they are now and not in the ITBs.
Re: New 24v ITB's
Post by Giuliettaevo2 » Thu Feb 13, 2014 1:10 pm
Just make aluminium plugs tot block the injector holes instead of welding them. Cast alu is not so easy to weld.
Re: New 24v ITB's
Post by 75evo » Thu Feb 13, 2014 1:17 pm
The outlet side is oval, I think the older triumphs have round ones. But it can be easily machined to round.
Re: New 24v ITB's
Post by kevin » Fri Feb 14, 2014 3:40 am
Great idea . Look forward to see the progress here .
yetyGTA
Re: New 24v ITB's
Post by yetyGTA » Sat Feb 15, 2014 2:03 pm
Some more pictures.
Will need to get the inlet pipe in S shape as the TB are quite wide.
Probably not that clear from the picture. But it is approximately 30° to go straight up.
Re: New 24v ITB's
Post by Mats » Thu Feb 20, 2014 12:17 pm
Giuliettaevo2 wrote:Just make aluminium plugs tot block the injector holes instead of welding them. Cast alu is not so easy to weld.
I bet the alu will distort slightly and mess up the shaft...
Plugs + hammer. :)
