'92 3.0 valve guides
Bruce
Post by Bruce » Mon Jun 10, 2013 1:43 pm
I'm confused.
I've taken the heads off to replace leaking head-gaskets.
Now, I was expecting to find steel valve guides but they appear to be bronze/bronze coloured.
I also have an old 75 head and that's the same too.
I assumed, maybe wrongly, steel was the way to go.
Were early smoky 3.0 litre engines (and 2.5) fitted with steel guides or/and was there differences in valve material?
Re: '92 3.0 valve guides
Post by Mats » Mon Jun 10, 2013 10:12 pm
Steele guides? Never heard of it to be honest..?
Bruce
Post by Bruce » Mon Jun 10, 2013 11:33 pm
Early V6's had smokey engines due to guides, which I presumed was due to bronze guides.
Post by 75evo » Mon Jun 10, 2013 11:37 pm
The 3.0s had the steel guides. But they are not good either. Both the bronze (which wear quickly) and the steel guides (apparently they shatter, according to my mechanic) should be replaced by the newer style manganese bronze guides.
BTW, I have stainless 3.0 valves (brand new never used) in case you are interested. Will sell for cheap.
Bruce
Post by Bruce » Tue Jun 11, 2013 12:57 am
Unless they are bronze manganese..... they are bronze coloured
SimonB
Post by SimonB » Fri Jan 10, 2014 7:14 am
How big a job is it to change them? My 2.5 has been smoking a bit on the over-run since about 2004. Must sort it out one of the days...
05 Corolla daily driver
Bruce
Post by Bruce » Tue Jan 14, 2014 2:02 am
I didn't change them, just changed the valve seals, cleaned the valves up and lapped them in.
I would suggest you take the heads to a machine shop and at the same time have 1mm off them to give you a bump in power - I've taken 1.5m (standard v6) and 1.1mm (QV) and use 95 RON with no issues.
SimonB
Post by SimonB » Tue Jan 14, 2014 2:47 am
I had the head done in 2000 in Spain and they skimmed the head then, I don't know how much. Used to pink on 95 ron so I used to use 98 or 100 when it was available. In the UK, I am using Tesco or Shell's 99 fuel, which the car likes. I think I am going to live with the wisps of smoke for now, ever see a classic Lambo that didn't smoke a little through the valve guides?
