main bearings crankshaft
gtv-racer
Post by gtv-racer » Wed Nov 26, 2014 3:57 am
Does any one know ore these are good bearings:
crankshaft bearing Sintered Bronze no overlay.
They are from rockauto.com
Don't know what the no overlay is. And ore the originals from sinterd bronze..?
Re: main bearings crankshaft
Post by MR2 Zig » Wed Nov 26, 2014 7:16 pm
That sounds too hard a material. It will wear well but any debris in the system will scratch and wear the crank. The bearings are supposed to be the cheap part that wears out and can be replaced inexpensively.
The bearing overlay, and the bit most likely to touch the crankshaft, is babbitt. It is a lead alloy.
I hope that helps,
Scott
gtv-racer
Post by gtv-racer » Thu Nov 27, 2014 11:41 pm
Thanks! Gonna get me some originals then.
