4 cyl flywheels - remind me?
Post by la_strega_nera » Sun Mar 01, 2015 5:27 pm
Alfetta 1800 and 2000 - same bolt pattern in the crank?
Used to know this shit!
1966 GTV
1982 Suzuki "Bathurst" Katana
Re: 4 cyl flywheels - remind me?
Post by MD » Mon Mar 02, 2015 1:42 am
Well given that you can transplant any crankshaft into any engine block of the Nord ilk*,it is extremely doubtful that Alfa would have changed the bolt patterns. Re-tooling is a costly business and so my best anticipation is that they are the same.
* Dont expect the stroke to remain the same.. :roll:
squadragrunn
Post by squadragrunn » Mon Mar 02, 2015 10:53 am
nope, 1,6&1.8 use 8bolts 2.0 uses 6bolts (if i'm not mistaken)
-charles-
Post by la_strega_nera » Mon Mar 02, 2015 3:31 pm
MD wrote:Well given that you can transplant any crankshaft into any engine block of the Nord ilk*,it is extremely doubtful that Alfa would have changed the bolt patterns. Re-tooling is a costly business and so my best anticipation is that they are the same.
Errrr... yes and no - you can put any of them in any block, but non 2l cranks won't line up with the bores in a 2l block (even with the offset rods), and vice versa.
squadragrunn wrote:nope, 1,6&1.8 use 8bolts 2.0 uses 6bolts (if i'm not mistaken)
105 1.6 and 1.8 definitely use 8 bolts, but the alfetta 1.8 crank I think is different cos a 1750 flywheel won't bolt on from memory?
Guess I'm going to have to go digging, got both cranks lying in a corner of the man cave, but can't get at them easily.
1966 GTV
Post by la_strega_nera » Mon Mar 02, 2015 3:47 pm
And confirmation that Alfetta 1.8 are a 6 bolt crank:
http://www.alfabb.com/bb/forums/engine- ... ments.html
1966 GTV
Post by la_strega_nera » Tue Mar 03, 2015 1:56 pm
Went digging into my stash last night, and also asked a bloke I know who has a few engines piled in a corner - Alfetta 1.8 is definitely 6 bolt like a 2l.
Case closed.
1966 GTV
