Re: Need s some advise on converting my Alfetta gtv 4 to a V
got the prop on yesterday
hard work on earlier cars without the removable centre support
everything is fine but would appreciate some help on the spacer size which go under the belhouse mounting bracket
its holding everything up
Thanks in advance
Thanks in advance
oh well for what its worth ive gone for 10mm which seems to sit right
after a few months of stopping and starting the project I have finally transplanted the v6 engine into the gtv 2.0l chassis
The wiring is all complete (I seem to remember an earlier post saying it was a couple of hours for an auto electrician which is correct in my case) the engine is running sweet as swish watch
my final hurdle is the throttle
on the 2.0l the pedal assembly is different to the v6 the v6 having a pivot and bracket on the bulk head (firewall) in the engine bay where as the 2.0l has it inside the bulkhead
therefore the cable is relatively shorter on the v6 than the 2.0
I haven't got a 2.0 throttle cable so was wondering how you did yours
this is the final major hurdle then its tidy up and mot time
Hi Daryl, have a look at the setup from a 75, the pedal mounts inside the cabin on its own bracket, so they have a longer cable that may be useful. Or use the whole setup if that's easier
Ben
Ben
thanks very much ben much appreciated
Ill look onto the 75 option
I could use the original gtv6 set up but it would mean a lot of whole drilling and a little alteration to the bulkhead and I'm sure there must be a simpler way
Ill post the results when ive sorted
Any other comments would be welcome
I had the same linkage type accelerator in my Giulietta, I used the 75 TS pedal box, plug and play, hugely recommend it.
chanced upon an s4 spider throttle cable on ebay
works perfectly keeping the 2.0l pedal assemble and a little mod at the throttle end
thanks for all your replies
conversion complete
just waiting for my bumpers to be painted then its finito
- 13537543_10210480605041395_5247197985661006342_n.jpg (90.82 KiB) Viewed 7928 times
- 13614965_10210480604681386_3274402806048878564_n.jpg (112.84 KiB) Viewed 7928 times
- 13592814_10210480603721362_3857853151719900257_n.jpg (104.38 KiB) Viewed 7928 times
It may be that you already have a plan for this, but you will want to get the computer box into the passenger compartment somewhere. I have no idea where it goes on a right hand drive car. On the US market cars it goes on the right side panel just in front of the door.
That looks really nice!!!
I hope this helps,
Scott
I hope this helps,
Scott
well spotted
I am re-loacating the ecu to inside the car and as you quite rightly said it goes neatly inside in front of the the door and under the fuse box
