Hey guys, so the other day i was wrapping my headers and when i pulled them off i noticed that my dashboard sided cylinders on both banks (i think cyl no. 3 and 6) both had a decent amount of oil in them. aswell as on the bolts for both these cylinders.
what could cause this?
Also could this be the reason my car is smoking at idle?
Check the rear of the engine close to the bonnet latch of the GTV6, particularly close to the V. If it's very very oily, then most likely the pressure gauge sender to maybe pressure light sensor is leaking a bit of oil.
Hmm, i had to do a clean of my injectors recently and didnt see any oil in the back of the vee but ill check again to be sure!
Thanks for the help. Its probably just stuffed oil rings, ill just have to face the music.
