v6 3.0 12v rebulid and mild tuning
smukc
Re: v6 3.0 12v rebulid and mild tuning
Post by smukc » Thu Sep 29, 2016 4:48 am
Just recieved NEW oil pump from OKP and i am shocked realy bad casting housing full of holes... :shock:
here are some pictures:
the guy from OKP said that this is ok...
What do you guys think ?
Post by MR2 Zig » Thu Sep 29, 2016 7:25 pm
As long as there isn't anything that can come out of the pits, its good to use. It isn't as efficient as it could be, but you won't be able to measure that difference.
I hope that helps,
Scott
cizeta
Post by cizeta » Fri Oct 14, 2016 12:06 pm
Sorry smukc, but I wouldn't put that oil pump in my engine, and I sure as hell wouldn't put it in your engine. I have built quite a few alfa engines, and this pump simply isn't up to factory specs. If you can't return it, you might be able to get a coating company to coat the pump and internals with an anti-friction coating. This is assuming that all the other clearances in the pump are o.k. As has been mentioned, the actual effect on measured oil pressure will not be noticeable, but you don't know what other unseen flaws the pump has.
