- junglejustice
GoTech Now With Datalogging!!!!!!!!!
You can down load the new program from their website or I will bring some CDs with the new program!!!
Very slick!
Very slick!
- junglejustice
- junglejustice
Got back late last night... (Actually emailed you from Frankfurt - free airport internet service....)
The airport has showers too - thank God for Germans!!!!!
Any way, yes download and then call me - I ma in Seattle - I also brought back some extra Pro units with coil packs if you would like to trade out and get rid of the last of the Bosch stuff along with the induction....
The Gotech software is available from the official website.
www.gotech.co.za in the downloads section.
The software is upgraded ofter so be sure to check it out every now and again.
Current software version: dealer tune v5. New features - datalogging and a copy function.
I downloaded the latest software today. It has some nice features such as data logging. I also like the "M" function that allows you to graphically see "continuity" in both "load" and "RPM" direction at the same time for both fuel and ignition.
One question: What does the "Auto Curve" function do? Didn't yet try it, but I will.
I'm currently running it in open loop, but do have a WBO2 hooked up that is connected to an Innovate Motorsports AFR meter (for tuning and monitoring). Any way to log that AFR along with the GoTech Parameters?
- twinspark6
I'm trying to download but do I have to own a gotech in order to see the way it functions? Does this datalogging show injector duty cycle? Afr? 02 mV? will it show spark advance and spark retard? Rpm and tps? Sorry for all the questions. Just wondering if the datalogging is up to par with other versions ecu that are on the market. Is it compatable with a knock sensor? Thanks, Marcelo
- junglejustice
Yes, I think you can, i.e. I believe I did that some months ago after tuning open loop before going closed loop. Without being online with the ECU, you cannot see your maps, though. Anyway, a bit confusing, but yes, I believe you can inspect the logged data at your leisure without being online with the ECU.Can you look through the log files without being online with the ECU?
- junglejustice
