Author Message
<  Race Cars and Track preparation  ~  No longer a ''budget" race GTV
PostPosted: Mon Jul 26, 2010 4:37 am
User avatarPlatinumPlatinumJoined: Thu Jan 26, 2006 1:53 amPosts: 381Location: Poznan, Poland
Any luck Kevin? :)
Btw. My uniballs have arrived, I have ordered the ones with ID of 10mm (for stock bolts holding the rods to the chassis). The tread is also M10, which seems a bit fragile to me. Will it hold the beating from all those lateral g's?
Offline Profile
PostPosted: Sun Aug 01, 2010 11:22 am
VerdeVerdeJoined: Sat Jan 22, 2005 9:09 amPosts: 1393Location: Gotham City ,South Africa
PietereQ, the lenght of rod is 44cm long. The uniballs are M12 with inserts where it bolts to chasis. check pics. you can see the bushes I made for chassis side, there attached with cable ties(not to loose them).
Offline Profile
PostPosted: Tue Aug 03, 2010 3:13 am
Thanks Kevin, that helps a lot! Still wondering whether to tap the rods or just weld the nuts on the ends. The id of rod is 10.90 mm so I dunno if the grooves of thread will be deep enough for M12, need to check it in the shop.
Offline Profile
PostPosted: Tue Aug 03, 2010 10:09 am
PietereQ, is not cheaper just to get a complete watts linkage from RS as youre in Europe unlike me with our import duties and freight its cheaper to buy a small car.
Quite excited about the new '' super lightweight '' front bumper spoiler combination for racing or for road. The combo unit is especially usefull for ultra low cars when loading onto trailers. Its moulded off the origional GTV 3.0 SA model front spoiler.
The only ''loose'' part are the side trims as you need to fasten the bumper on sides to body as per origional design. The combo unit is made from two moulds (bumper and spoiler) in order to maintain origional looks.
Check out pics pf progression to get to this point
Offline Profile
PostPosted: Wed Aug 04, 2010 11:03 pm
GoldGoldJoined: Fri Dec 03, 2004 12:50 pmPosts: 96Location: Brisbane
Man i wish i was that clever to make things like that, Kevin they look great. Still grumpy about the bonnet!!! maybe you need to move to Aussie and bring all your clever stuff with you. Brisbane is magic.
Tom
Offline Profile
PostPosted: Thu Aug 05, 2010 12:18 pm
fortom, i think you gotta be stupid to make parts for a 26year old car. :)
There has been surprising a lot of interest for the parts (rear bumper, front bumper, spoiler, spoilercombo and 3.0 boonet) so a friend of mine has decided to export this stuff from my moulds. This stuff is so light. As julian is now flying to SA on a semi regular basis maybe he can load a whole kit for you. Dont want to talk prices on this link as its not a vendor section but will work out something .
Trying to finish clutch still but got major problem with cnc machine as its cutting concaves which should be convexes. Waiting for help to find problem when downloading from laptop to cnc (corruption of G2, and g3's).
Offline Profile
PostPosted: Sat Aug 07, 2010 3:12 am
SilverSilverJoined: Fri Oct 14, 2005 6:18 amPosts: 4Location: Centurion, South Africa
Kevin,
Do you have front bumper/spoiler combo and rear bumpers available? Can you please PM me availability and price. I'm in Centurion.
Thanks
T
Offline Profile E-mail
PostPosted: Sat Aug 07, 2010 12:40 pm
Hi Theunis, sent you pm.
Offline Profile
PostPosted: Tue Aug 10, 2010 12:57 pm
Kevin that could be a plan, just need to get the car from New Zealand hopefully in the next month and get it roadworthy here in in Brisbane then we will talk.
Cheers
Tom
Offline Profile
PostPosted: Wed Aug 11, 2010 11:05 am
No problem, look forward to it.
Offline Profile
PostPosted: Sat Sep 04, 2010 2:14 am
User avatarVerdeVerdeJoined: Mon Nov 22, 2004 2:37 amPosts: 1697Location: Brisbane, Australia
Kevin, you still need to fix your alternator problems?
_________________
Transaxle Alfas move my world.
PostPosted: Sat Sep 04, 2010 5:59 am
VerdeVerdeJoined: Tue Jun 13, 2006 9:47 pmPosts: 599Location: Fresno, Ca.
Kevin, you can edit the program in the cnc machine likely faster than you can troubleshoot you cam software. You should be single stepping thru the program on the machine anyway when you do the setup, so just make the changes there. All that should change is the G code and the + or - values. You should see it in the tool path display also.
hth,
_________________
Offline Profile
Display posts from previous:  Sort by:
Page 10 of 10
147 posts Go to page Previous  1 ... 6, 7, 8, 9, 10
Users browsing this forum: No registered users and 1 guest
Search for:
Post new topic  Reply to topic
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
