JJ, As you are running a similiar injection system to me(my 3.2 GTA 116) in terms of using a 155 coil pack with semi sequential firing - wasted spark I would like to know how long your spark plugs are lasting. Mine did 300km only which is obviously seriosly wrong. The problem lies within my leads, suppressor and connection point to the 155 coil pack which only measures 2.5 kohms. I have been told change my suppressors to at least 20kohms . If the leads are cold the car is great but after hard driving it starts to misfire. I noticed this detrioration in performance and immediately blamed the fault on my haltec system like most people do when they cant find the problem. Anyway I brought this up here incase you start getting any misfire problems and start stripping elsewhere. I am using NGK bcp plugs. Can you let me know what yours measure.
Cheers
Kevin
What's your heat range?
Mats, its a bcp 6es.
Sounds like a start-up plug. I'd go colder.
junglejustice
Post by junglejustice »
Hey Kev!
With the 11.9:1 motor and race gas Dawie recommends at least an 8, but preferable a 9...
Unfortunately I have not done enough running with the motor in that car to draw any conclusive ideas about the 155 coil-packs and the GoTech and that motor... When I do, will respond here again!
JJ, found the problem with regards to chainging sparkplugs like underwear so need to worry about 155 coil pack set up(not that you were). Problem was the home trigger in my hall pick up sensor which was faulty(bad ,rusty connection). This threw the injector phasing right out and toatly overfueled the plugs when out of phase.I destroyed a set of plugs in 50km's. Anyway all sorted. Bottom line its never the system,its about maintenance.
Whats happening on your car at the moment.
junglejustice
Not much. Ron has been here visiting for 5 weeks and we made trips to California to hang out with ol' Jes and skiing up at Mt. Baker etc...
Open house at Group 2 today (visits to the collections next door at John Goodman Racing, Bill Cotter's and Ken McBride's...) Ford RS200, Jacky Ickx 312, original GTAs, things like EFI Corvette #1, the French Connection Le mans Vette, 410 SA (Super America), a 500 Superfast, GTs, GT40s, Ford Big Block Cammer motors (SOHC 427 - 2 of 5 or so built are next door - one in a boat and one in a Galaxie), etc etc.
Ron leaves on Sunday and then I can get back to work on completing the 3.7. Got the 6-speed GTA-boxed 3.45 litre 24 valve 164 LS (Super) going now too and need to do some sorting there as well.
junglejustice
Re: 2nd US-Based 3.7 Litre 24 Valve Milano/75!
So, don't know if anybody cares, but Jes and I finally had these two beasts out on the track at Pacific raceways together last Thursday! What a rush... :shock:
Cool!
Is there any video or piccies to be seen???
zig
JJ, we sure would like to see some pics. They have got to be fast as i have just been reading a full road test(Oct. speed&sound) they have just done here on a one of Dawies 3.7 156's.(road car) 0-60km 2.99sec, 0-100 5.26sec, 0-260kmh 36.6 sec. and im sure yours is much quicker. You got to pay serious attention on the track with that power.
junglejustice
So - I don't understand it (and yeah - I could have glued a video to my car), but in the days leading up to all of this, we arguably had a bit more to think about than mounting cameras or who would be holding a video camera track-side...
Sorry guys - no video of the two 3.7s then I guess. Still, here are some pics; mine has the black wheels & black dials and Jes' has the white wheels & silver/white dials... Brad's blue car is the hot 12 valve 3.0 with the wing and Keith has the red 2.5 with the serpent on the side. Chris' is the black 2.5 with the snow-plow upfront and big gay wing on the rear as well.
I'll get some video next time. :oops:
alfa pics 202.jpg (33.83 KiB) Viewed 8681 times
alfa pics 199.jpg (49.5 KiB) Viewed 8680 times
alfa pics 197.jpg (73.92 KiB) Viewed 8682 times
alfa pics 192.jpg (52 KiB) Viewed 8607 times
alfa pics 190.jpg (44.88 KiB) Viewed 8681 times
Last edited by junglejustice on Mon Sep 29, 2008 7:56 pm, edited 2 times in total.
junglejustice
Some more...
alfa pics 228.jpg (59.91 KiB) Viewed 8597 times
alfa pics 220.jpg (67.63 KiB) Viewed 8594 times
alfa pics 211.jpg (82.62 KiB) Viewed 8597 times
alfa pics 206.jpg (49.75 KiB) Viewed 8670 times
alfa pics 203.jpg (57.55 KiB) Viewed 8667 times
junglejustice
...and a few more...
alfa pics 237.jpg (53.58 KiB) Viewed 8586 times
alfa pics 235.jpg (66.69 KiB) Viewed 8659 times
alfa pics 233.jpg (63.87 KiB) Viewed 8659 times
alfa pics 231.jpg (70.91 KiB) Viewed 8656 times
alfa pics 230.jpg (84.22 KiB) Viewed 8654 times
junglejustice
Last ones!
alfa pics 245.jpg (67.49 KiB) Viewed 8691 times
alfa pics 208.jpg (67.1 KiB) Viewed 8574 times
alfa pics 242.jpg (54.58 KiB) Viewed 8690 times
alfa pics 241.jpg (63.59 KiB) Viewed 8684 times
alfa pics 238.jpg (63.34 KiB) Viewed 8681 times
