perfect suspention for racing
Posted: Sat Jun 14, 2008 4:18 pm
by escon64
i have heard that there is a combination of torsion bar with rear springs.......???? also some people say about a combination of shocks.........bilstein in front and koni in rear ??
front sway bar ????mm .....rear sway bar ??????mm
PLEASE ADVICE.....GTV 2.0 ...1978
do i have to reinforce my chassis?????? can i go for 30mm torsion bar???
mats.... what is your combination in your car
thanks in advance
:twisted: :twisted:
Posted: Sat Jun 14, 2008 11:06 pm
by kevin
What is your budget and what are your regs and are you prepared to weld chassis.
Posted: Sun Jun 15, 2008 12:15 am
by Fris75turbo
Posted: Mon Jun 16, 2008 5:50 pm
by escon64
[quote="kevin"]What is your budget and what are your regs and are you prepared to weld chassis.
budget no problem.... yes, i have my welder ready......reg in suspention not much
TRANSMISION PARTS : STD GEAR BOX
(NO CLOSE RATIO GEARS)
LSD : STD ZF / ALFA ROMEO
DRIVESHAFT : STD
SPRINGS : PERFORMANCE SUSPENSIONS
(IAP OR CENTERLINE TYPE)
SHOCKS ABSORBERS : KONY OR BILSTEIN.
BUSHINGS : POLYURETHANE OR OEM BUSHES.
CONTROL ARMS : ADJUSTABLE UPPER ARMS.
Posted: Mon Jun 16, 2008 10:43 pm
