Re: Original GTV 3.0l race car build gearbox upfront (Nelso
Posted: Sat Dec 24, 2011 12:46 pm
Hi Kevin,
The 12 valve supercharger kit will not bolt to the 24 valve engine. Some of the parts may work, but at a minimum the main (forward) mounting bracket will not, and that's a key component.
For the record, 24 valvers are very rare over here. If there is even one here in Oklahoma, I don't know about it. I doubt there are more than a few hundred running in the entire country.
The new supercharger I am planning to use on the 2.5 will have enough capacity for any Alfa V6, including the 3.2 GTA engine. However, as I said, bolting it up is another issue.
The crank pulley on the 24 valver may be a blessing if it can be used to drive the blower. Otherwise, something else would have to be fabricated.
