Re: A new GTV6 2.5 entry into SA Marque car catergory
Thanks Kevin.... great to see u in SA - pity about the rain (the first rain we have had in about 3 months)....the car was really flying I must say.... and Dawie did a great job!!!! - u are right about the brakes..... it now feels like I am trying to slow down an express train....
eventually did a 1:15.8, but I am DEFINITELY not extracting everything out of the car by any stretch of the imagination... never thought I would ever say this, BUT I need, yes me, need to get more seat time, as the car at present is faster than me
I was actually using 5th gear down the back straight yesterday..anyway will post some short video clips soon
ok... lets see if this works..
https://www.facebook.com/photo.php?v=10 ... =2&theater
Hi.. a short clip of weather from car vid... slippery
http://youtu.be/xVDZ0Yqiis8
Below find some pics of the Brakes Upgrade done..
4 pot Brembo, 308mm disks, 29.5mm wide.... AND they fit under a 15" Rim!!!!!!!!!... and does it stop!!!!!!!!
- spacer used
- 4 pot brakes 5 spacer.JPG (46.34 KiB) Viewed 7672 times
- View thru the wheel
- 4 pot brakes 1.JPG (110.03 KiB) Viewed 7672 times
- front view
- 4 pot brakes 2.JPG (99.89 KiB) Viewed 7672 times
- Top view - had to "file" a little bit of caliper... but not bad
- 4 pot brakes 3.JPG (124.96 KiB) Viewed 7672 times
- disks BEFORE fitting, sloted and hardened
- 4 pot brakes 4.JPG (73.54 KiB) Viewed 7672 times
mmm, looks familliar
-charles-
Looking good , nice to see the spigot on spacer . . Which pads you using ? Looks like the box is EBC blue . Its least now you have the stopping power for that motor of yours . Just remember when they balance the wheels to put the weights near outside as they could catch on caliper .
Hi... here is another soundd and video clip, driving by, but hit rev limiter in 2nd ...
http://youtu.be/PIcn-TnoGtc
Those front brakes look absolutely awesome, sure look like they work like a bomb.
GTV6 2.8 TT Race Car
GTV6 3.0 White
GTV6 2.5 Red
GTV6 2.5 RIP (donor)
GTV6 3.0 White
GTV6 2.5 Red
Re: An original GTV6 3.0 entry into SA Marque car category
So, just for interest, measured the front and rear track.... the values are as follows:
Front = 1688mm ----- original 2.5V6 = 1373mm
Rear = 1662mm ------original 2.5V6 = 1352mm
I has a "Small" problem with the front touching on the rear of the wheel arch when on full lock, but managed to resolve it with a little "man handling"
the above is measured at the outside extremities of the tyre contact with floor.......which is probably NOT the way it normally gets measured?
ok... re-measured to centre of tyre....
Front = 1489mm
Rear = 1463mm
Front = 1489mm
Rear = 1463mm
They say it better to be wider in front than back on the gtv6 but in your case with hat super powerfull gta motor I might want the back wider
I also had to knock the body work back in the rear of the front arch . I ended up putting some heat on it in order to hit the seam flat but you gotta watch you set the car on fire inside . You will loose the splash guard but that's not a problem for a race car in a rust free environment .
