Project 2 : front mount SA GTV 3.0 - Sei diff
casta28
Post by casta28 » Thu Apr 04, 2019 8:20 am
do you have pictures of the new driveshaft with bmw differential?
I've infinite problems with the mix bmw rubber joint/cv rear joint, now we try with double cv joint but now I see you advise against to use it..
KevinR
Post by KevinR » Mon Apr 15, 2019 3:20 pm
I'm still using the sedan diff in my car with a one pice prop of 850mm long with two CV and a torsion resilient tube with no problems and perfectly smooth. I had problems when I had universals as the angles were greater than 3degrees and off in both planes . This is my prop
KevinR
Post by KevinR » Mon Apr 15, 2019 3:30 pm
This is my friend's car who has used my flywheel and clutch set up with same ZF box as mine. He has used the X5 3.0 diesel prop with CV at back , rubber at front . No problems at all.
KevinR
Post by KevinR » Sat May 25, 2019 2:26 pm
On the previous page I was working on the dash and heater unit. I have finally got my heater bracket made . Can’t help myself by putting and Alfa badge on it even though it’s under the dash and no one will eve see it 😂😂😂
KevinR
Post by KevinR » Sat May 25, 2019 2:40 pm
My dash is in .. thanks again to Richard for flocking it . Waiting for my fuel sender gauge to fill vacant hole .
Slow progress as many projects on go but should be ready for trackday next month ! Thinking dash looks better so car should go faster :wall:
