Windage Tray
Windage Tray
Post by Mats » Thu Jun 16, 2005 1:07 pm
Seems a bit tight to fit a piece of sheet metal under the lock-nuts as you can see.
On top of the locknuts looks a bit better...
Measuring across.
So, any ideas? Would be nice to add some stiffness by bridge the oilpan flange and the main cap nuts like Jim Stecks design but I'd like to add a piece covering the crank to let oil drain away from the crank as it rotates.
Have anyone here done this?
Maybe it's time to do a CAD study... :roll:
Maurizio
Post by Maurizio » Thu Jun 16, 2005 1:32 pm
:? had the same drawing, I think.
Recently converted it into UG but didn't take the time yet to make a 1:1 plot. And place it onto the TS bottom end.....
Post by Mats » Thu Jun 16, 2005 1:50 pm
TS should be the same, the dipstick is not in the same position but everything else should line up.
Why plot it when you can lasercut it? :wink:
Maurizio
Post by Maurizio » Thu Jun 16, 2005 11:43 pm
:lol: Couldn't convince my boss to buy a laser cutter yet ( or ever ).
The adding stiffness story, I wanted to have a look at that first, before taking this route.
Post by Jim K » Fri Jun 17, 2005 7:51 am
Why don't you get the set Paul Spruell sells?
http://www.paulspruell.com/motorsport/r ... parts.html
Pay the guy $190 and get the best!I put it on two motors here and everything fits great! :wink:
Post by Mats » Sun Jun 19, 2005 1:06 pm
Looks like Jim Stecks design to me...
http://www.autocomponenti.com/performan ... _parts.htm
But anyway, I want to add something that covers the crank and I'm not sure I like that the exhaust side is closed up like that.
Looks stable though. :)
Post by Mats » Tue Jun 21, 2005 2:38 pm
Did some pre-prototype testing today just to try some stuff, took some pics for you guys, this is what I meant
Opening up the exhaust (downward) side by adding a slot where the line is or just cut away the whole area inside the line and dotted lines?
Add a second piece of sheet metal under the crank to keep the air controlled and the oil drained down to the sump, maybe something like this?
This is just a test of course, the "louvres" are supposed to be at a tangent to the crank. This is just to give an idea of how it could look.
So, any thoughts?
Maurizio
Post by Maurizio » Tue Aug 09, 2005 5:28 am
Mats,
any further development in this area?
I 've to start on the scraper in a few days....
Saluti,
Maurizio
Post by Mats » Sun Aug 14, 2005 7:27 am
I have done a complete CAD model of a new prototype, I have had so much other stuff to do lately (and the guy that does the cutting has been on vacation) so I haven't got around to do any solid stuff yet.
Hopefully I'll cut some metal soon.
