zambon
anyone have specs for custom A arms
Post by zambon »
Does anyone have specifications/measurements for custom A arms? I would like to commission the production of a set for one of my verdes but I am not the person to make the design :oops:
I would like to go to coilovers on the car, so torsion bar compatability is not necessary. That said, it would be a plus, I am not one to burn bridges...
James
TurbMarc
Post by TurbMarc »
81GTV6
Post by 81GTV6 »
Why do you want new A-arms? Does the current set up not allow coilovers?
If whatever club/class i choose to race my car in allows it i will probably end up making steel tube A-arms to match the 50mm offset at the rears. Most likely that wont be of much help but if the prosses turns out easier than expected i wouldnt mind taking orders.
Jacob Ricciotti
'81 GTV6 3.0
'81 GTV6 Track car
'91 164S daily driver
ar4me
Post by ar4me »
Upper control arm has tight clearance for coil-over. Lower A-arm is heavy.
