gtv-racer
new 42mm primary headers!
Post by gtv-racer »
Never seen these before. Won't fit my 75....
Looking good!
http://www.extreme-tuning.bg/en/project ... a-s-Y-pipe
Re: new 42mm primary headers!
Good solution to keep the pipes nearly equal length without running into a ground clearance problem.
When I set out to make properly sized 24v headers, I considered this design and the more traditional CSC style. I opted for the latter, since I strongly object to adding great amounts of heat in the engine compartment, preferring instead to unload it in the airstream under the car. The shown solution may be fine for a race car, but not for a daily driver with all sorts of rubber tubes and wires running next to the hot pipes. Thermal coating may be a half ass protection measure but still grossly inadequate in this case.
Hmm, I hadn't really thought about the heat issue. Now that you mentioned it, it will add a lot to the underhood temps. Although.. I doubt they could possibly add more than the Callaway. That thing had upwards running manifolds with non liquid cooled turbos on top of them.
