75 Upgrade
Weekend Warrior
75 Upgrade
Post by Weekend Warrior » Sun Oct 06, 2019 7:53 pm
So after a couple of years of being on this forum I've finally worked out how to post photos so should start a thread on my little project, originally a motor swap into the GTV but its an early split dash so with values rising have decided to keep it original and have some fun with the 75 which i bought for the gearbox only.
Have acquired a 3.2, 4 pot Brembos, RS suspension and an exhaust from Jim,
met some really helpful guys from here that make it possible, updates to follow...
Weekend Warrior
Re: 75 Upgrade
Post by Weekend Warrior » Sun Oct 06, 2019 8:00 pm
Weekend Warrior
Re: 75 Upgrade
Post by Weekend Warrior » Sun Oct 06, 2019 8:02 pm
KevinR
Re: 75 Upgrade
Post by KevinR » Mon Oct 07, 2019 11:50 pm
Hi , Weekend Warrior :) I have several conversion bits and pieces for that engine. I have made extras of these every time I did this conversion. Parts that I have are front thermostat conversion, bracket to attach alternator, oil filter attachments with threaded insert , trigger wheel( 60-2) pick up sensor bracket, flywheel spacer when using a 2.5 flywheel and aluminium plates laser cut for the plenum to make a tapered side plenum. Pm if you’re interested.
I really like the engine stand you have !! Super cool 😎
Here is link to few bits
Link to parts 1)
viewtopic.php?f=5&t=2648&start=105
Link to parts 2)
viewtopic.php?f=5&t=2648&start=45
75evo
Re: 75 Upgrade
Post by 75evo » Tue Oct 08, 2019 6:12 am
If you need runners, I got a set from Beninca. Also a Siamese twin GTV6 plenum to mate with the runners.
Weekend Warrior
Re: 75 Upgrade
Post by Weekend Warrior » Thu Oct 10, 2019 7:38 pm
Thanks Kev and evo, got a few local parts on order but sure I'll need some of your goodies
The stands have generated a bit of interest, did some for my neighbour with his logo, here's another colour scheme,
Weekend Warrior
Re: 75 Upgrade
Post by Weekend Warrior » Sat Nov 30, 2019 9:02 pm
A quick update...
IMG_0940 (1).jpg (209.45 KiB) Viewed 69 times
