more pics, ...
pic 68_24.jpg ... MARRIAGE !!!
- Alfa 75 Racer
Re: Alfa GTV 916 2,0 V6 TB bring back to life after 12 years
- Picture 68_assembling_20.jpg (168.11 KiB) Viewed 2760 times
- Picture 68_assembling_21.jpg (193.55 KiB) Viewed 2760 times
- Picture 68_assembling_22.jpg (173.85 KiB) Viewed 2760 times
- Picture 68_assembling_23.jpg (158.4 KiB) Viewed 2760 times
- Picture 68_assembling_24.jpg (168.81 KiB) Viewed 2760 times
Last edited by Alfa 75 Racer on Mon May 16, 2022 12:08 am, edited 1 time in total.
- Alfa 75 Racer
more pics, ...
pic 68_27.jpg ... solenoid for electronic boos control via potentiometer located in middle console.
Poti will give a signal to ECU, so it knows how much boost and then via MAP Sensor and WIDE BAND LAMBDA adjustment of injection and ignition.
pic 68_29.jpg ... had to make an adapter for fuel pressure sensor on lath ou of a squared aircraft aluminium bar.
- Picture 68_assembling_25.jpg (170.21 KiB) Viewed 2759 times
- Picture 68_assembling_26.jpg (172.82 KiB) Viewed 2759 times
- Picture 68_assembling_27.jpg (176.79 KiB) Viewed 2759 times
- Picture 68_assembling_28.jpg (184.73 KiB) Viewed 2759 times
- Picture 68_assembling_29.jpg (102.74 KiB) Viewed 2759 times
- Alfa 75 Racer
more pics, ...
- Picture 68_assembling_30.jpg (170.03 KiB) Viewed 2753 times
- Picture 68_assembling_31.jpg (182.42 KiB) Viewed 2753 times
- Picture 68_assembling_32.jpg (186 KiB) Viewed 2753 times
- Picture 68_assembling_33.jpg (178.77 KiB) Viewed 2753 times
- Picture 68_assembling_34.jpg (202.9 KiB) Viewed 2753 times
How has the final dyno session gone? What type of oil are you using in that motor ? Do you have a reservoir for cold oil to run back into turbo once you switch off . I saw this on a some factory Alfa turbos in SA
Hi Wolfgang
Hows the project coming along ? I believe you have made some headlight upgrades. I do enjoy this thread as so much info to be gained from your engine mods which is this engine has been used a few times in conversions into the 116 GTV6.
