Giulietta24vTT
Post by Giulietta24vTT »
Micke wrote:Speaking about welded bolts. I had to change to longer ones about 10 years ago as my mag rims were really thick.
The bolts rotated in the holes and my friendly neighbor welded then to the hub. Removed the box and dedion yesterday and everything still looks fine.
Seems like he had done avery good job then :) , it's not that easy to weld on that cast iron hub, usually needs to be pre-heated and the use of the correct cast -welding electrode(or cast iron filler wire pn tig).
Chen S
ex Giulietta 24V Glenwood TT.
He said it is a bit tricky and used some special electrode.
In this field he know his stuff. Welded some cyl heads and cast exhaust manifold for me as well.
Sporttunergtv6
Post by Sporttunergtv6 »
I have been waiting almost a full 3 months for special order Gta rotors from brembo. I am just about ready to fly over there and pick them up my self. Never mind chamfer the spigot hole... my size 12 is about to chamfer some brembo ass!
Hey Sporttunergtv6 don't hold back mate ! Why not take JK along with you, he's good at that sort of thing. :D :D
Tuner:
It shouldn't take that long to swim to Italy. Just the way back is heavyish with them rotors on your back :lol:
rz
Post by rz »
my new gta set just arrived!!
brembo gta 2e serie 004.jpg (155 KiB) Viewed 10693 times
rz
Post by rz »
BIG 330 mm disks at 61 EURO plus tax original alfa!!
brembo gta 2e serie 011.jpg (133.88 KiB) Viewed 10692 times
rz
Post by rz »
504 euro for two BIG calipers tax included also original alfa romeo gta 2ND series
brembo gta 2e serie 006.jpg (134.89 KiB) Viewed 10689 times
rz
Post by rz »
another picture!
brembo gta 2e serie 013.jpg (130.81 KiB) Viewed 10683 times
Jose_76
Post by Jose_76 »
WOW!! RZ, where did you get that stuff? That's a very good price!!
I didn't know that new GTAs had different calipers, those ones are easier to fit in my GTV6 than mines! :(
'84 Red GTV6 3.0
rz
Post by rz »
the new gta has bigger calipers and bigger disks 330mm and because the first series were bad on the 156 and 147 i think the second series is cheap!!www.tuynder.nl is the address to get original alfa spares for low prizes.
patzo_3l
Post by patzo_3l »
are you still running the booster with that setup? and what about master cylinder size? if u plan on keeping the rear brakes standard have u thought about a step master cylinder like used in some of the older mercedes and such.
patzo_3l
3l gtv6 turbo 85'
2006 147 gta selespeed
1990 75 twinspark
1998 spider
2.0l gtv 85'
33 1.7ie
rz
Post by rz »
the brakes are not yet on the car,but i am planning to leave everything standard.when the pedal travel will be to big i will place a 25mm mastercylinder from a 7 series bmw.
patzo_3l
Post by patzo_3l »
oh ok fair enough. well hurry up and let us know how u go already lol. i think the 25mm master may be the way to go though.
patzo_3l
3l gtv6 turbo 85'
1990 75 twinspark
1998 spider
2.0l gtv 85'
33 1.7ie
Jose_76
Post by Jose_76 »
RZ, please keep us informed about the mods you'll need to do make it all fit on your hubs (stock, aren't they?)
'84 Red GTV6 3.0
