I wonder if anyone had drawings for adaptor plates needed inorder to mount the brembos from GTV 3,0 24V or 166 3,0 on the AR 75 TS. Or if anyone has any to sell or know where i can buy a pair. I am thinking of using the Brembos and the front discs from either the GTV or 166 on my 75 TS.
I also wonder about the master cylinder. I read in some threads about uppgrading that some of you have asked about changing the master cylinder to bigger ( I remember a BMW model being mentioned). Is this done to match the cylinder efficiency to the bigger calipers? I wonder because my car has rebuilt rear brakes with AR 164 3,0 rear discs and AR 33 1,5 front calipers, in the rear mounted at the wheels and I feel the pedal travel to be too long/much. Can it be because the AR 33 calipers are bigger than the standard ones?
