Page 2 of 2
Posted: Wed Feb 13, 2008 4:01 am
by PietereQ
OK. So I'm gonna buy the vac bleeder, new copper lines, second, bigger (grrrr!) bmw MC, and keep you posted on results (which may take some time cause I killed my clutch on thre track this weekend :cry: )
Posted: Wed Feb 13, 2008 5:39 am
by sh0rtlife
copper lines?!?!?!?..think you mean steel
buy the vac bleeder and make 100% sure all air is out of the system befor moving forward.....when you think your done stick the tappered adapter on the bleeder and hold it with some force inside the hole in the reservoir that feeds the brakes...you may pull a few small bubbles from here...and dont forget to tape those bleed screws so you dont suck air in around them
also when you think your done tap the calipers with a screwdriver handle you may pull a few more little bubbles out
when your done take it for a run around the block and then try bleeding it again and see if you can get any last air out...you shouldnt but might get the tinyest bit out
Posted: Wed Feb 13, 2008 6:35 am
by MR2 Zig
I just thought .....did you bench bleed the master cylinder before you hooked up your lines to the calipers?
By 'bench bleed' I mean to put tubes from the MC outlets (all) into the resivoir and pump until you get no bubbles anywhere. Then hook up your lines to the calipers. Then bleed as normal.
Scott
Posted: Tue Aug 05, 2008 12:40 pm
by kterkkila
I've heard about BMW master cylinders with different piston size for front and rear brake. Does anybody know about those? What sizes are available?
Posted: Wed Aug 06, 2008 12:16 am
by Giuliettaevo2
i had one from a mercedes on my 33 with 164 callipers up front. that used two sizes piston in the MC. wish i had known this before i bought it because the 33 uses a diagonally split brake circuit.... :oops:
It caused the car to pull hard on the steering wheel when you braked. :( was later solved by using a BMW MC.
Don't really know about the sizes anymore, something like 23/19mm. :?
Posted: Thu Aug 07, 2008 1:02 am
by Maurizio
From memory, I can't find the data:
I have ones searched through an ATE catalog and found a cylinder with a stepped size 23/19 same mounting interface as a 75 but couldn't figure out from what car it came.
I vaguely remember something of an old MB 250 cylinder.....
Posted: Thu Aug 07, 2008 10:29 am
by Giuliettaevo2
i believe it was a 300TD from around 1990... :wink:
33 uses the same mounting as a 75, so it could be the one... :?
