zambon
wilwood conversion
Post by zambon »
Which wilwood caliper is the most compatable with the stock milano 75 master cylinder (non abs)?
I read on the old forum that the 1.75in piston dynalite is too big for the stock master. The conclusion was to go to smaller pistons.
I see two options on www.pitstopusa.com:
1.62in piston billet dynalites and
1.38in piston forged dynalites ($60usd less).
Both are one inch rotor width, is this correct?
Zamani,
What kind of master cylinder-caliper combination are you running? Did you stick with the non-turbo supra rotors?
I am thinking about using the Nissan maxima 280mm rotors on your suggestion. I want to use 15in wheels.
James
Zambon,
Why don't you get my setup? I'll sell it to you for a reasonable price. It's a good setup, but I want to try something different. I used a 164 alloy MC, 24mm I think. Email me for details.
zambon
Post by zambon »
Zamani,
I sent you a PM.
