gtv11636
speed bleeders ?
Post by gtv11636 »
Hi Guys
well, just wondered if anyone here using them and wanted to hear your opinions.
Tomer :D
Murray
Post by Murray »
Tomer I have speed bleeders on my 86 GTV6 and they work very well.The only point of caution is the driver side rear caliper.One of the two bleeders (I can't remember if it's the inside or outside) may be too close to your exhaust pipe as the speed bleeders are longer than stock.In my case I returned to stock for this one to avoid contact with the pipe.
gtv11636
Post by gtv11636 »
Thanks, but I guess I wont have this problem as my exhaust pipe goes the other way
I have GTV4 not 6 :D
AlfaBeta
Post by AlfaBeta »
Hi gtv11636,
They do work really well but I'm not sure how long they last. The first few times I've used mine they worked perfect. The last time I used them they did let some air back in however.
AlfaBeta
tomp
Post by tomp »
Get one for your clutch slave !
