To prove a point, I mock-assembled the Brembo + bracket on the spindle and hub and put it inside the 16" Compomotive MO, using spacers. True enough,there's just enough room for 332mm discs (yes, 332) with ~2mm caliper/wheel clearance.In real life, a 10.5mm thick alloy plate will go where the spacers are. With this setup, front brake swept area is 280sq" (total for both wheels) vs 196sq" for std brakes, but a lot more important than area increase is the huge mechanical advantage of the larger diameter.
- P2260006a.jpg (169.02 KiB) Viewed 8501 times
Don't forget the lager mass for heat "storage" and dissipation.
Leverage is good but if you can lock up the wheels in 200Km/h+ there is no real gain.
Matts from my viewpoint, the larger surface area will dissipate heat faster from convectional scrubbing and radiation and will take longer to build up heat as well. So there are obvious advantages for some circuits and less so for others.
Add to that the mechanical advantage which enables you to use it carefully makes this set up really attractive.
There is a weight penalty which can be offset to a degree with alloy composite rotors.
..anyhow, I am biased 'cause I have 16" wheels so I need to talk myself into it haha.
Just love that tricky little conversion brkt Jim.
Barry, the type of wheel is everything. In the 15" MO's I have the same setup with 310x28mm discs. As a matter of fact, Compomotive advertise their wheels for being some of the roomiest around for brakes. Some years ago, AP Racing had their disc application catalog configured around these wheels, so they could maximize size.
Too bad they are British though. Brits can be the most troublesome and stubborn people in the world...
But then again, some of them are just the nicest and friendliest ever to do business with.
