Some more brake upgrades for the 116.
Re: Some more brake upgrades for the 116.
Post by Giuliettaevo2 » Sat Nov 16, 2013 2:27 am
The attention to detail and the amount of work gone into the finishing are breathtaking. :shock: Those callipers are better looking now then they ever were. :)
Post by SydneyJules » Thu Jan 23, 2014 3:29 pm
Mate! You've stepped it up a notch here! Amazing job!
May I ask how you cleaned the calipers?
I'm about to start on my 166 ones and had planned to use oven cleaner and isopropyl alcohol ...
shiny_car
Post by shiny_car » Sat Jan 25, 2014 12:42 pm
I depends what condition the surface of your calipers is.
The calipers I bought were the bare metal version. In Ti cars (ie: 159 Ti), they are of course painted red.
I cleaned mine with wax&grease remover, but isopropyl alcohol would be ideal. On areas of corrosion, I ground them back using a Dremel with a 'wire brush' attachment. If you have areas of corrosion, you can do the same; if not a Dremel, then a brass wire brush attachment on a power drill, like here: http://pic20.picturetrail.com/VOL166/13 ... 791832.jpg (Bunnings sell them).
Otherwise, just sandpaper the paint (eg: 400 grade wet and dry then 800).
Post by Mats » Sat Jan 25, 2014 1:53 pm
Hang on a minute...
Are you on the 155 board..? 8)
shiny_car
Post by shiny_car » Sat Jan 25, 2014 6:43 pm
Mats wrote:Hang on a minute...
Yes indeed. :)
And several other Alfa boards! :D
Post by Mats » Sun Jan 26, 2014 10:42 am
I knew I recognized that attention to detail from somwhere... :wink:
casta28
Post by casta28 » Wed Nov 12, 2014 3:12 am
In my ex car I mount this.. 305x28 disc redrilled from renault master and renault clio rs calipers (also same punto abarth, corsa opc, mito qv)
Jose_76
Post by Jose_76 » Fri Jun 12, 2015 11:31 pm
I've just found a couple discs suitable for conversions in addition to the well known GTA 305x28 and 330x32 discs:
Brembo 09.8003.10 (285x28, 5x98) From various models (Citroen, Peugeot, Fiat, etc..)
Brembo 09.7680.20 (310x32, 5x98) From various models (Citroen, Peugeot, Fiat, etc..)
Hope this helps
'84 Red GTV6 3.0
